1970 Q-Jet Choke
1970 Q-Jet Choke
I'm restoring a 70' 350/350 with the stock cast iron manifold. I can choose between a Q-Jet with a divorced choke or electric choke.
The car will be driven around 5000 miles per year.
Which choke setup will give me the least problems? If electric, where do I connect the wire from the carb? Thanks for your help.
If it's a fair weather car, you don't really need a choke at all. That said, perhaps the divorced choke would be best, simply for the sake of originality. It'll work fine.
70/99rdstr
I ran my 72 350 for 3 years without a choke because it was a fair weather car, and it always started hard (part of this could have been due to the dilapidated state of the internals due to 10 years of sitting). However, when I finally got around to installing the choke last summer, the car started 200% better (ie. less cranking of the starter, fewer occurences of the car dying, etc). I've just started the rebuild on the engine this spring so I'm a firm believer in having a choke!
trw
trw
