vinyl paint on metal ?
Old 03-07-2005, 06:56 PM
bams12
bams12's Avatar
Default vinyl paint on metal ?
I am redoing my vinyl interior parts with vinyl paint and I need to also do the steering column parts and the ashtray door on the console . The difference being that they are made of white metal , not vinyl. Can they be painted with the vinyl paint so they will match the surrounding parts ? Thanx Brent
Old 03-07-2005, 06:59 PM
kona
kona's Avatar
I don't think it will stick.Maybe if you primered it first it will thou.
Old 03-07-2005, 08:11 PM
aussiejohn
aussiejohn's Avatar
Default Yes, maybe......
It worked for me, but I gave the steering column a good clean up with thinners first. I used VHT vinyl spray and did it over a year ago and although I haven't yet driven the car, there are no signs of it coming off. I get in and out of the car a lot while working on it and it doesn't budge. I'd say go for it, but make sure the metal parts are clean first.
Regards from Down Under
aussiejohn
DorianC3 (05-04-2019)
Old 03-07-2005, 11:11 PM
rtpilot
rtpilot's Avatar
You can use the vinyl paint if you use a metal or rubber or plastic primer first. I bought some of this stuff from Eichlers years ago and am still using it today.
Old 03-08-2005, 08:04 AM
79blue
79blue's Avatar
I agree, used it on the column and horn cap. just wipe down with a cleaner and primed (Kraylon metal primer). Let it dry for a few days before working around it.
It will scratch easy untill cured.
Old 03-08-2005, 09:54 AM
mooneyd
mooneyd's Avatar
It works fine on metal I gave it a light sanding and cleaned really well with alcohol and sprayed with VERY light coats. Came out perfect, matches vinyl to a tee.
To vinyl paint on metal ?
Quick Reply: vinyl paint on metal ?
