What is the typical cost to have a business media blast parts?
I called a local business to inquire to their charge for media blasting some of my rear end parts. They said they charge a minimum of $35 or $50 per half hour. Is this considered a fair market rate? They don't use a blasting cabinet. They take the parts outside and blast in an unenclosed environment.
"Free" for life at 2 of my friend's shops!
Originally Posted by Frankenvette
I called a local business to inquire to their charge for media blasting some of my rear end parts. They said they charge a minimum of $35 or $50 per half hour. Is this considered a fair market rate? They don't use a blasting cabinet. They take the parts outside and blast in an unenslosed environment.
if it's small parts, i would just buy a small cabinet and do it yourself....see if you can borrow or rent a good compressor......
b
b
b
b
I thought about this but...1) money is all tied up in rear end rebuild 2) I need to blast differential and crossmember which won't fit in small blast cabinet.
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
35-50 isn't a bad labor rate. Especially when you consider the wear and tear on his equipment, electricity to run the compressor, and the cost of media. My business charges $100/hour for service work, many are higher (heating and cooling service)
I can't help you with the blasting as I'm overseas or you'd be welcome to come and use my cabinet. what I wanted to comment about is when you blast anything mechanical clean, clean, clean and again clean before reassembly, blasting media will go anywhere and will ruin any moving parts in no time if there's any left
I blasted a differential I have apart on Saturday night. It took a good 20 minutes to do but came out nice. I'm going to paint it with POR15 anyway so I didn't really need to blast it.
If you're not going to open it up I wouldn't blast it anyway- you'll get bead inside for sure and then you will be rebuilding it. Wire brush it, use the metal ready, black POR15, top coat it with a cast blast, and clear coat and you're done.
Gary
Gary
Gary
Gary
I have had parts done several times at a local shop. He charges $90 Can per hour ($60 US). It may sound like a lot but it is a big sandblaster that they use outside and he gets alot done in a short time. I recently had these parts done and it cost me $40 CAN cash.
I have a small blast cabnet but it would have taken me like 10 hrs to get that much done with my compressor.
Would it hurt to use engine degreaser assuming it will leak into the diff? I don't plan to rebuild it but will have to open it up to reinsert one of the side yokes. The c-clip was missing even though the tip of the yoke is still good with plent of material left. In doing so, I plan to replace the fluid anyway.
Don't forget to get a bottle of the limited slip additive to add with the gear oil.
Ummm hummm...a buddy of mine worked at a shipyard, and you talk of sandblasting??? try what THEY do, in about a second all the parts of a dozen corvettes are blasted inside and out....
THAT's POWER.....it's nuckin futz to watch that in action....
GENE
GENE
