How much can a 76 handle?
Horsepower that is, running 11 inch tires in the rear (not slicks), will the frame twist if there is too much torque or will the tires just spin? Thanks in advance
I doubt the 'frame will twist' without true slicks.
Besides, I'm guessing you'd bust the rear-end long-before you suffer frame-damage.
You had better strengthen the rear and half shafts before worrying about the frame. The stock IRS will hold about 500 HP on street tires and that is no guarentee. Slicks and things will break. 600 to 650 you had better get some HD parts back there.
What was done to the rear end to "beef it up"?
Gary
Gary
New gears, ring and pinion, positraction carrier, carbon fiber clutch pack, stub shafts, seals, everything on the inside is new basically, 3.55 ratio. Not worried about the differential or driveline. Just wondering if the frame can handle it if it has a 650 hp engine and is running 11" summer tires that aren't very sticky?
The frame could use some gussets in places.
Good luck,
Gary
Premium Supporting Vendor
Originally Posted by Van Steel
- What he said Of course that still doesn't address the differential parts. For that I would use heat treated 10-17 spiders, polish and tune the carrier and clutches, use solid steel clutches, use steel bearing cap with 1/2-13 socket cap screws on the left and 7/16-14 cap screws on the right. Use solid pinion sleeve,Tom's 355's, HD yokes and HD cover. The next step up would be a 12 bolt conversion.
Gary
