Water pump rebuild
I asume that you are trying to keep your numbers matching pump. Have you tried the local yellow pages? If you can't locate a rebuilder, there is a company here on Long Island that does an excellent job and uses your pump, If you don't have any luck , send me a PM and I'll get the name and # for you.
I had mine rebuilt as I wanted to retain the correct numbered pump and I think it was by a gentleman named Bill Mock if my memory is correct. I found him in Hemmings Motor News.
Please post a source for the kit if you find one.
Gary
Gary
Just guessing, but I would bet they are off-the-shelf bearings and seals.
The numbers should be right on them, and any good parts store
should be able to find a replacement.
