Tire sizes for '75 Stingray....Please Help!
Old 04-15-2005, 11:22 PM
blue_stingray75
8th Gear
blue_stingray75's Avatar
Default Tire sizes for '75 Stingray....Please Help!
Hello,
I need some assistance regarding tire sizes for my '75 Stingray. I know that the factory original size is 225 70 15. I just purchased a set of
15 x 8.5 aluminum American Racing 15-spoke cyclone wheels with Corvette center caps and I am looking for a good tire combination for the car.
Right now the car has 225 70 15's on the front and 235 60 15's on the rear on 15 x 8 factory rally wheels.
I was thinking about keeping the 225 70 15's on the front and trying to go with 245 60 15's or 255 60 15's on the rear. However I don't know if the 245 60's or the 255 60's would work on the rear...I am concerned about clearance.
Any help and / or recommendations would be appreciated.
Thanks,
RJ
Old 04-15-2005, 11:31 PM
GDaina
Support Corvetteforum!
GDaina's Avatar
you can run the 245 on front without any problem, and certainly no problem running the 255's on the rear...ditch the 225 70's
Old 04-15-2005, 11:35 PM
Tom73
Tom73's Avatar
I have 245/60 all around on my '73, no problems
tom...
Old 04-15-2005, 11:37 PM
79Cruzer
79Cruzer's Avatar
I put a set of BFG TA's (245/60/15) all the way round on my '79 last year and have been happy with them. No rub on the front at all.
Old 04-15-2005, 11:42 PM
blue_stingray75
8th Gear
Thanks for the replies so far.
I should have asked this in my initial post...but didn't think of it...
Any pictures with these tire combos?
Thanks,
RJ
Old 04-16-2005, 01:47 AM
holley505
holley505's Avatar
255/60r15 all the way
275/60r15 rear 205 R 15 front
Old 04-16-2005, 02:31 AM
ACECO
ACECO's Avatar
St. Jude Donor '04 & '05
255/60/15 all the way around w/factory rally wheels on the 75 in my sig pic. Very slight front rub at full right lock. FWIW.
Hope this helps.
Old 04-16-2005, 09:48 AM
SteveG75
SteveG75's Avatar
255/60R15 's here. No rubbing. More pics in my gallery.
They are the same height as stock so it avoids speedo errors.
The Radial TA's are OK but I will not be buying new ones (thinking Yoko's).
Old 04-25-2005, 06:15 PM
blue_stingray75
8th Gear
Steve,
Hi...this post was from a week or two ago. I just wanted to check again...on the BFG Radial T/A's 255 60 15...no rubbing problems at all on the front?
Actually...my car already has the 255 60 15 on the rear...not worried about that. Just concerned about the front. I read from another forum member that there is a slight rubbing on the front when turned to lock position. They will be going on a 15 x 8.5 inch rim.
I hope you don't mind me asking again...just wanted to be sure before ordering the tires.
Thanks,
RJ
Old 04-25-2005, 07:45 PM
Maymyvetteliveforevr
Maymyvetteliveforevr's Avatar
My last set of tires on the 75 were 255/60r15's on the rear with no problem and 245/60r15's on the front with a 8 inch rim. I took the 255 off of the front cause there was a slight rub when I turned the steering to hard. I now have 275/50r15 on rear and 265/50r15 on the front, but had to rework the emergency brake cable as we all know.
Old 04-25-2005, 09:36 PM
SteveG75
SteveG75's Avatar
Originally Posted by blue_stingray75
Steve,
Thanks,
RJ
RJ,
I have no rubbing with 460# coils, cut 1/2 coil. However, the build tolerances on these cars is such that one car will rub were another will not.
Steve
Old 04-25-2005, 10:33 PM
HDFLH67
HDFLH67's Avatar
RJ: Did you get my e-mail? Do you want the lug nuts for those wheels? Be glad to send them no charge if you want them. Jeff
Old 04-25-2005, 11:12 PM
MYBAD79
MYBAD79's Avatar
St. Jude Donor '05
here's mine: 255-60 front and 275-60 rear ( 1" spacer on the rear for additional clearance)
Old 04-26-2005, 12:51 AM
cchristo
cchristo's Avatar
Hey REDBAD1979! You just had to post your picture, didn't you! My car needs repainting, and the wife is insisting that it be painted red. I want to keep it black. You are not helping my argument!!!!! Very good looking car.
Sorry, didn't mean to hijack the post. Ummm, I run 255 all the way around. No clearance problems.
Old 04-26-2005, 05:22 AM
ACECO
ACECO's Avatar
However, the build tolerances on these cars is such that one car will rub where another will not. Steve
My car came with the 255/60/15's on it when purchased so I will live w/the slight rub until they need replacing. You just learn not to turn the wheel full lock. However that said when the time comes, I'll probably go w/245's on the front.
I would also think that by going w/a 8.5" wheel vs the 8" stock rally that you may find that what works/doesn't rub using the 8", might just touch w/the 8.5" due to the slightly wider profile that your going to end up with. FWIW.
Good Luck!
Old 04-26-2005, 07:26 AM
MYBAD79
MYBAD79's Avatar
St. Jude Donor '05
Thanks !!
It's a 5 year old $500 paint job.... looking closer it's pretty ugly.... it was originally black ...
Old 04-26-2005, 08:03 PM
blue_stingray75
8th Gear
Jeff,
Hey...how did you know it was me?! Yep...got your e-mail. I just sent you an e-mail regarding the lug nuts.
Later,
RJ
To Tire sizes for '75 Stingray....Please Help!
Old 04-26-2005, 08:12 PM
blue_stingray75
8th Gear
Well...after much thought, I think I will go with 245/60/15's in the front and 255/60/15's in the rear on the 15 x 8.5" wheels.
With the luck that I have... 255/60/15's in the front are sure to rub...I really don't want to deal with that. From the sounds of it... the 245/60/15's on the 8.5" wheel for the front should be fine with no rubbing problems. I would assume that it shouldn't throw the speedometer off by all that much.
I'm thinking that I will get the BFG Radial T/A's. I had them on my '86 Monte Carlo SS and had good mileage with them.
Thanks,
RJ
Old 04-26-2005, 10:49 PM
MYBAD79
MYBAD79's Avatar
St. Jude Donor '05
Thanks,
RJ
The front tires don't affect the speedometer.
Old 04-27-2005, 02:35 AM
vttedrm
vttedrm's Avatar
255 60 15's front and back
Quick Reply: Tire sizes for '75 Stingray....Please Help!
