Vibration at 2500 RPM.
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
We took the 1980 out for a long cruise today, and noticed a vibration that has me concerned.
At about 2500 RPM I get a vibration that shakes the car pretty good. It does not mater what gear I am in so it's not driveline related. It will happen at 50 MPH in 3rd or 80 MPH in 4th.
I feel that it is coming from the motor, but what would cause this. It's a stock ZZ4 crate engine with that is 4 years old but less than 10K miles on it.
Any ideas or suggestions?
Is it an auto or manual?
A friend installed a V6 in a hotrod he was making and had this really annoying vibration that was dependant on engine rpm, it turned out to be a faulty torque converter.
Another idea, and please pardon my ignorance but is the ZZ4 crate motor externally or internally balanced? How is the harmonic balancer?
cosmicvette
cosmicvette
Originally Posted by bobs77vet
fan clutch.......check this out....
This was a problem with mine when I first installed the rebuilt motor. I wound up taking out the clutch fan and installing an electric.
CI 6-7-8 Veteran
It is a 700R4 transmission. No fan clutch because I have converted to electric fans.
It wouldn't be the drive shaft or pinion snubber as it happens at different speeds but at the same engine RPM. Driveshaft would happen at the same speed but at different engine RPM depending on gear.
Torque converter is new - less than 2K miles on it.
How can I check a balancer?
Make sure if/when you pull it that the druff key is OK and that the cranks keyway is not beat up.
If it's auto wouldn't you get the same vibration in neutral at that RPM ?
I am having the same problem as you only mine is 5 speed and it is just a slight vibration mainly in the shifter at about 2500RPM not too bad but enought to let me know something is not perfect.
Both of us can rule out anything after the tranny from the driveshaft back because it happens in every gear at the same RPM and is not dependant on speed of the car.
Now mine does not vibrate in neutral with the clutch engaged so this tells me the motor is OK which makes sense because I did not have the vibration before installing new transmission, so I am baffled too.
Motor mounts is interesting though, I never really thought about that I might go to the poly mounts
Originally Posted by isosceles
does it do the same thing sitting in the driveway out of gear?
would a bad balancer produce the same results if revved in neutral?
CI 6-7-8 Veteran
Originally Posted by ESU
It's not a tire out of balance is it?
I will have to have someone rev it up for me while I check under the hood.
Did this vibration develop suddenly or has it always had some vibration at ~2500 rpm?
While parked, put the car in neutral and slowly rev it up to the point where you feel vibration. This will eliminate all sources other than the engine, engine accessories, and torque converter.
You can unbolt the torque converter from the flex-plate and slide it away from the engine. Rev the engine to see if the vibration is still present.
Perhaps you have one cylinder that is misfiring under load!?!
Good luck and keep us posted.
same problem on '78
I have the same problem out of my 78 vette. My vibration starts at ~3500 RPM and eases up at ~4500 RPM in every gear no matter the speed. I have a 4 speed manual trans.
