Nascar mechanical fuel pumps ?
Just saw something about the Nextel cars running mechanical fuel pumps in the stock location. It looked like a ordinary fuel pump. Anyone know who makes them ?
I guess another question would be is : If they make a mechanical fuel pump that can stand up to the rigors of that kind of racing with 800HP motors why does anyone need an electric pump for a 500HP street/strip motor ?
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Those are most likely made by Holley or Barry Grant or someone like them. I am sure they are far from "stock" but they do mount in the stock location.
And yeah, they last 500 hard pounding miles, but then I am sure they get rebuilt or tossed in the trash.
I want one that will last 100,500 miles without worrying about it.
Actually there isn't any need for electric fuel pumps, mechanicals work just fine. No need for fuel injection either, carburetor(s) work just fine. No need for fancy ignition systems either, HEI's work just fine.....and the list goes on........................
I think I heard Holley, I was always under the impression mechanical pumps were good to certain point then you had to go to electric pumps but these pumps work fine to 10,000RPM on 800HP motors. I have always thought mechanical pumps were adeqaute for the street and this kinda backs up what I thought.
Older Than Dirt: No need for HEI....points work just fine.
Dep
i was interested in the other one that they had shown. the one that is driven off the rear oil pump. My only question is: Wouldn't they have a problem with the car stalling if the car was running and not moving???
there is a pressure reg. with a by-pass... the cable to drive the pump come's off the dry-sump pump on the "left" side of the engine, doesn't hit the wall as often
Originally Posted by DJ Dep
. But if I remember right, NASCAR mandated that the new mechanical fuel pumps be relocated to the back of the car Dep
not to be a stickler here but what drives a mechanical pump on the rear of the car?
stickler: See Aflac's post "the one that is driven off the rear oil pump."
The new one is gear-driven off the oil pump. No idea what drives the oil pump.
Dep
Dep
The oil pump is driven by a belt. The Nascar motors are pure race motors with dry sump lubrication system. I think they have two oil pumps on a common shaft, one is the pressure pump to lubricate the engine and the other is a scavenge pump to take the oil out of the pan and put it back in the oil tank. The cable to drive the fuel pump is hooked up to the back of the oil pump drive shaft. Electric fuel pumps are banned because in a crash an electric pump could stay on feeding gasoline to a fire. By the way, the new pumps are not mandated, yet. Nascar allows teams to build their cars with the cable driven fuel pump if they chose, but they can still run the old style pump driven off the side of the engine from the cam if they want to instead.
...redvetracr
Originally Posted by youwish2bme
Also don't the oil pump's run off the rearend not the motor so the mechanical cable driven fuel pump really isn't that long of a cable...
NASCAR uses 5 and 6 stage pumps (I have a 4 stage in my car). The pump on the pinion is for a rear end and if two stage for the trans cooler as well.
...redvetracr
...redvetracr
Yes the stock location Nascar pumps are a problem because when you hit the wall they get damaged rather easily due to their location.
My point in posting this was the perception ( on my part only ? ) that mechanical pumps fell short once you reach a certain HP but this looks like it is not the case. I know these Nascar pumps are expensive because they are billet aluminum but you could make one exaclty the same out of cheaper materials that would flow good enough for any street/strip hot rod. Now the only advantage for electric would be less HP drag on the motor but an electric setup costs much more that a mechanical pump
Dep
