Quick Barry Grant carb Question..Any Barry Grant users out there??
I am trying to find the model number of my demon carb. Anyone know how I can find it on the carb??
Thanks,
Joe
Thanks,
Joe
i think you will need to use visual cues to determine what you have, go to the Barry Grant web site they be able to help you out.
I knew you were going to be the first person on this. You are the man!!!
I know it is a mighty demon. I am pretty sure it is a 750.
what about other ques?
What else should I look at?
I will have to look at it I guess..
Thanks,
Joe
P.S. going to look at website now
sorry wish i could help you more on this, i looked at my speed demon and the only numbers i saw was on the base plate, the instruction manual didn't say anything either. good luck bob
I think it is 5402010GC, but I am not positive.
thanks agian for the help...
Joe
Here you go:
http://www.barrygrant.com/demon/defa...e=29&specs=29d
5402010GC is the 750 Mighty Demon Carb. I have the same one on my 406.
Originally Posted by VETDRMS
Here you go:
I saw that on the website.
I think that is the one I have.
Thanks agian,
Joe
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Actually, if you go to this BG page, it will give you the stamping number location and codes of the BG carbs:
http://www.barrygrant.com/demon/default.aspx?page=38
You identify the carbs by visual clues (for basic model type) and by the code in the carb. The complete part number is not stamped into the carb.
Lars
Lars
Originally Posted by NHvette
You were supposed to have that info posted weeks ago.
I am so stupid!!!!!
Thanks,
Joe
Lars
Lars
GC = General Competition
If it is a 750 Mighty Demon:
1) It will have mechanical secondaries
2) The Venture size is 1.40"
3) If you remove the metering block and bowls the emulsion bleeds will be non-removable
4) The boosters will be non-removable
5) The air-bleeds will be removable
my brother bought the carb and he says it is a mighty Demon 750.
It does not look like a speed or roda demon. (does not have that piece on top for the choke)
I think it is part number: 5402010GC, but I am not positive.
I think the GC is casted on the carb somewhere, but I have no idea where?
Thanks,
Joe
To identify the application type (drag race, blower, general comp, etc.)the two-letter code ("GC", "BC" etc) will be stamped into the top of the main body next to the secondary vent tube.
Lars
Lars
Lars
Lars
If he can find it, I will have an answer in ten minutes or so....
Thanks for the clarification Lars.
Joe
NO luck!!
my brother looked at it, but could not find anything.....
He said there was a "40" on top, but I think it refers to the size of the venturi diameter. (40 = 1.5")
I will check it out when I get home....
Thanks,
Joe
Thanks,
Joe
