LT1 conversion, Radiator hoses question
Location: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Alot of the conversion threads I have seen the folks use Cool Flex Hoses , THey are a tad pricey but what I am wondering is what alternatives are there for a similar style "universal" type hose and what lengths would I need for my 77 LT1? I am running an aftermarket Summit alum. radiator.
Cruise-In X Veteran
St. Jude Donor '06
Hey these are pretty inexpensive compared to the others I have seen.
Any experiences out there with Mr Gasket's version of these?
http://www.jegs.com/cgi-bin/ncommerc...44&prmenbr=361
That said, I wish it came in another color - greasy rust - to match the rest of my engine.
Get 'er dun.
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
swap, with a T-56, you have any pic's of your swap
Cruise-In X Veteran
St. Jude Donor '06
Originally Posted by MEGALADON
Not sure if I can help you with your question, I am fixin to do the same
My setup is an LT1 with a ZF6 out of a 92 using an ACCELL/DFI computer. The computer is going to be my biggest job because although I have the software for this particular computer it is by todays standards antiquated and tuning modern drivetrains is not one of my skills YET, and this thing is running like it is way out of tune. I was also considering selling off the ZF6 and going with either a T-56 or 2004R eventully but that is not for awhile.
Cruise-In X Veteran
St. Jude Donor '06
Originally Posted by Stumpdeisel
Make sure you use a high pressure cap. The LT1's were known for overheating because the cap can't hold the extra pressure...
What PSI?
Cruise-In X Veteran
St. Jude Donor '06
Originally Posted by flood
I know this doesn't help with your question but..
With the reverse cooling of an LT1 do you just hook up the stock radiator backwards?
OK , I may be talking out of my *** here so if I am wrong someone will correct me.
From what I am seeing everything is hooked up "normally" I believe that the reverse cooling is done at the Waterpump through the engine but the radiators are setup and flow the same as any other.
Cruise-In X Veteran
St. Jude Donor '06
Originally Posted by NHvette
Any stainless hose is gonna outlast most of your other components.
Get 'er dun.
Get 'er dun.
I'm Trying, REALLY I am LOL.
See ya Sat!!
