Torque Thrust II's wheel nut torque
Old 06-11-2005, 06:10 AM
73jst4fun
73jst4fun's Avatar
Default Torque Thrust II's wheel nut torque
The torque for American Racing TT II's says 50-65lbs. which seem a little light, what are you guys torquing your wheels at....
Old 06-11-2005, 07:01 AM
VETDRMS
VETDRMS's Avatar
Huh, I have always torqued mine to 105 lbs.
Old 06-11-2005, 07:14 AM
Paul L
Paul L's Avatar
Mine are at 80.
Old 06-11-2005, 08:44 AM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
90 Ft lbs.
Old 06-11-2005, 08:46 AM
stingry
stingry's Avatar
80 also
Old 06-11-2005, 09:35 AM
CruisinCO
CruisinCO's Avatar
80-85 is fine
Old 06-11-2005, 12:20 PM
73jst4fun
73jst4fun's Avatar
Thanks guys, thought that was light but that what it says for 7/16" studs.....
Old 06-11-2005, 01:42 PM
norvalwilhelm
norvalwilhelm's Avatar
Originally Posted by CruisinCO
80-85 is fine
That's what I always set the torque wrench too .
Old 06-11-2005, 06:08 PM
Boofers
Boofers's Avatar
According to Haynes & Chilton the stock rallies should be 70 and the stock aluminum 80. I went with 80 on my aluminum wheels...
Is it really a big deal? I have seen guys at wheel shops simply set thier air tools to 'high' when they put lug nuts on. I guess I'd rather know for sure my nuts are torqued properly.
Old 06-11-2005, 07:52 PM
427V8
C6 the C5 of tomorrow
427V8's Avatar
Originally Posted by Boofers
According snip---
Properly does not mean Really f-in tight. Proper means to the proper torque.
That is dependant upon the material the stud is made from.
Old 06-11-2005, 08:38 PM
mandm1200
mandm1200's Avatar
[QUOTE=427V8That is dependant upon the material the stud is made from.[/QUOTE]
There's a little more to it than just what material the studs are made. If that were the case, then why are are there different specs for steel ralley versus the aluminum. Accordingly, then GM used different material for the studs for the aluminum wheels.
The best torque specs should come from the manufacture. If the studs are not original or OEM equivalent, it would best to call them to be sure. 50 ft/lb does seem awfully low.
To Torque Thrust II's wheel nut torque
Quick Reply: Torque Thrust II's wheel nut torque
