Need Help, where is turn signal flasher located?
Old 06-25-2005, 01:32 PM
69monzaredbigblock
69monzaredbigblock's Avatar
Default Need Help, where is turn signal flasher located?
I've located the hazard light flasher in the fuse block, now where is the turn signal flasher located? My wiring diagram shows 2 flashers for a 69. Do I have to take the instrument panel apart? Turn signals light up but won't flash so I can't find the flasher by listening to it click. Help. Thanks.
Old 06-25-2005, 01:39 PM
luerja
luerja's Avatar
flasher is located behind the lower right (passenger side) dash cover. If your lucky you can take a flashlight and look up under there and see it. If not then take out 7 screws and your there.
Mostly it is near the circular air vent.
Jim
Old 06-25-2005, 01:48 PM
69monzaredbigblock
Thank you. I was looking on the drivers side. Thermometer says mid 90's but I'm going to find this thing anyway. I'll let you know if I'm sucessful.
Old 06-25-2005, 01:54 PM
69monzaredbigblock
I found it. Thanks. I feel like a dope. No wonder people question my skills!
Old 06-25-2005, 05:37 PM
luerja
luerja's Avatar
To Need Help, where is turn signal flasher located?
Quick Reply: Need Help, where is turn signal flasher located?
