voltage at terminals
Old 09-13-2005, 12:42 PM
madvette74
madvette74's Avatar
Default voltage at terminals
on my super coil, i have 3.5 volts when the car is running, this is at the terminals on the coil.. should it be more
Old 09-13-2005, 12:51 PM
big_G
big_G's Avatar
The ignition side should be approx. 12 volts, a little less if yiu are still using a resistance wire or ceramic resistor. The distributor side is pulsating d.c., can't really spec. this (don't need to measure).
Old 09-13-2005, 12:55 PM
Russ Bellinis
Russ Bellinis's Avatar
Typically a resistor or resistance wire is put in line in before the coil to reduce the voltage to the coil. The purpose is to protect your points from arcing and prolong the life of you condenser. If your engine runs good and doesn't cut out under load, it's ok.
Old 09-13-2005, 12:58 PM
fl_rider
fl_rider's Avatar
More primary voltage equals more secondary voltage equals hotter spark.
To voltage at terminals
Quick Reply: voltage at terminals
