Dragvette Safety Loops & 3 inch Halfshafts
Old 09-20-2005, 07:35 AM
b71vette
b71vette's Avatar
Default Dragvette Safety Loops & 3 inch Halfshafts
I have a C3 383 stroker 490 Hp/TQ and presently using the stock 2 1/2" halshafts with new U-Joints / no grease zerks which I purchased from ZIP and Van Steels offset trailing arms.
I was going to purchase and install the Dravette Safety loops as a precaution. Do you think it's a good idea to go with the 3 " Halfshafts as well ?
Dragvettes sells a set of 3" Halfshafts with Spicer Ujoints and Flange for $218 which I believe is good price.
Anyone out there using these Dragvette parts - are you please with there parts and service ?
Old 09-20-2005, 07:58 AM
brianlewis60
brianlewis60's Avatar
halfshaft loops are the best idea anyone ever had. I hope you will never need them but if you do then you will be happy that you got them. The 3" shafts are not a bad price either. what are you going to be doing with the car? just cruising the blvd or hardcore trans-brake launching at the track?
Old 09-20-2005, 08:18 AM
b71vette
b71vette's Avatar
Default brianlewis60, I will be using for Cruisng mainly ,
but may be doing some occasional hard lauches too.
Are you familiar with the Dravette products?
Old 09-20-2005, 08:48 AM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
I have the safety loops and they're top notch
Old 09-20-2005, 09:02 AM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
I don't know if the loops will work with offset arms. You may have to do some fabrication b/c I believe they designed the loops for stock arms which have a flat bump plate and the offsets use a round one.
Old 09-20-2005, 09:38 AM
73 Vet
73 Vet's Avatar
DragVette parts are top-notch.
Old 09-20-2005, 10:23 AM
ruby76
ruby76's Avatar
Location: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Sorry to hijack, but anybody have a picture of the safety loops installed? I've heard of them, understand their need, but can't picture it.....
Old 09-20-2005, 10:26 AM
lilgto
lilgto's Avatar
You have to mention that you want the loops for offset arms so that he can send you the correct rounded ones.
Mike
jimvette999
jimvette999's Avatar
Here's a reply from DragVette about this issue.... I asked if it would fit my offset trailing arms. He said:
"Jim
Yes they will just specify you have offset trailing arms and we will sent you the appropiate ones. You will have to drill 2 small 5/16 holes in the bumper pad of your trailing arm to attach the safety loop. You will use the safety loop as the pattern it is very simple.
Thanks Steve @ Dragvette.com"
Hope this helps......Jim
Old 09-20-2005, 10:28 AM
SmokedTires
St. Jude Donor '05
Here you go
Old 09-20-2005, 11:14 AM
Van Steel
Van Steel's Avatar
"Jim
Old 09-20-2005, 12:09 PM
Nate '69
Nate '69's Avatar
Hey Smoked... like the shot and the red accents..
Old 09-20-2005, 12:14 PM
brianlewis60
here is an up close shot of a loop in action. dragvette is very highly rated and top notch company
if I were you I would get the loops and try it out and see what the car reacts like and if you break a shaft then replace with 3" but more than likely you will bust u-joints long before a shaft goes
Old 09-20-2005, 07:34 PM
b71vette
b71vette's Avatar
Default Thanks for all the Feedback
this forum is a great resource, don't know what I would do without having you all to help me out.
Old 09-20-2005, 08:59 PM
litevette
litevette's Avatar
Yours looks welded in. I take it the bottom of the loop is removable. That's not for your year C3 is it?
Old 09-20-2005, 09:08 PM
b71vette
b71vette's Avatar
Default I have the VBP dual mount rear spring
with the Van Steel offset trailing arms will the safety loop fit with no mods other than drilling the 2 holes on the round bump pad ?
To Dragvette Safety Loops & 3 inch Halfshafts
Quick Reply: Dragvette Safety Loops & 3 inch Halfshafts
