headlight actuator seals
Old 12-10-2005, 03:14 PM
palazzopl
palazzopl's Avatar
Default headlight actuator seals
Is it possible to replace the seals on a 81 with out removing the actuator from the car
Old 12-10-2005, 05:06 PM
vabeachvette
vabeachvette's Avatar
I have a 73 and getting them out is no too bad, I don't think I would have been able to replace the seals while the were in, I changed mine about 8 months ago, if you are unscrewing the clevis then you only have a few more bolts to unscrew to get the actuator free. Lots of good info in the archive about taking them out. Good luck.
Old 12-10-2005, 07:47 PM
gator79
gator79's Avatar
Default dont think so
I rebuilt my actuators a while back and it would have been next to impossible with them in the car. work from the top with the hood open and then close it and finish from the bottom. you have more room with the hood closed.
Old 12-11-2005, 07:55 AM
jdp6000
jdp6000's Avatar
Yes you can replace the front seal with out removing the actuator. Open the head light. Take off the fiberglass trim ring around the bulbs....work through there. You can then reach just about everything.
I recommend complete removal. You can try with them in and if all else fails then take them out.
Jim
Old 12-12-2005, 09:23 AM
palazzopl
palazzopl's Avatar
just ordered all the parts, I'll try it in the car first, if that fails I'll remove the actuators Thanks for the feed back
To headlight actuator seals
Quick Reply: headlight actuator seals
