Oil Pressure line
Oil Pressure line
Hi All,
This may be one of those questions where the answer is obvious, but I must ask it anyway. Will air spaces in the oil line from the engine to the pressure gage effect the accuracy of the reading on the gage? I can see empty spaces in the clear plastic line between sections filled with oil. Must the plastic line be completley filled with oil to give an accurate reading, and if so, how do I go about purging the air from the line?
Suggestions welcome.
Originally Posted by big_G
Pressure is pressure. It won't affect the gauge accuracy. The line will fill with oil evenually.
the line does not fill up with oil untill you break the fitting at the gauge and bleed like a brake line.
as for the reading ???if you have air in your brake line the pedal will feel very soft ,or you will not have any brakes,so I must disagree with this quote(pressure is pressure)
St. Jude Donor '07
With brake systems, your pressure is limited by the master cylinder stroke. On an engine, the oil pump will exert a constant pressure on the oil in the line, regardless of the air. You can only have a pressure drop to the gauge if there is a leak or restriction in the line.
more of an observation,
but when you shut the car down, the oil pressure bleeds off, and since the oil pressure line is not a sealed system (no one way valves to keep oil in the line) some of the oil will drain back into the block over time, even if you prime the line. Right? So, air is bound to enter the line.
BTW, I just replaced my OP line. After pulling the block, the line was so fragile that it cracked and broke off in my hand when I tried to secure it out of the way. While I was at it, I decided to have my clock fixed (clockworks) and, I cleaned all electrical contacts on the gauges, and replaced all of the bulbs in my instrument cluster.
Ready for the engine now.
You can compress air, but not oil (at least not much). However, I think that the effect is negliable. Burgundy 69, One thing you may want to consider to keep your pressure line from becoming a radio oiler, is to put a safety line around it. Just go to the Home Depot, and get on size larger line. SLide it on, and zip tie it, or safety wire it to the fittings, over the top of the pressure line.
