71 LT1 engine info
71 LT1 engine info
Ok 71 LT1 owners, can you give me some info on the 350/330 hp. I'm looking for the rotating assembly specs: piston type/manufacturer, bore, stroke, crank...GM numbers if you had them would be great....Also GM offered a replacement engine with those specs but I cant find any info....Thanks for any help you can forward...
Emerging Vendor
71 LT1 pistons are forged TRW with single valve relief, shotpeened con rods, forged steel crank 4 bolt main block. Solid lifter cam, hi pressure oil pump, 202/160 valve heads with screw-in studs/guidepates, hi rise aluminum intake and 780 holley carb.
Greg
Greg
Greg
Greg
Originally Posted by 73jst4fun
Thanks Greg for that info, compression was between 9-10 for that engine?
Emerging Vendor
The factory rated the 70 at 11 to 1 compression and the 71 and 72 at9 to 1 compression. You can still get the correct single relief flat top piston.
Greg
Greg
Greg
Greg
