Milling down plenum divider
Old 02-22-2006, 08:12 PM
MikeC
MikeC's Avatar
Default Milling down plenum divider
In the intake manifold.
Are there any real benefits on a 400HP street engine? I have the engine apart and I am thinking of milling down the divider on my Edlebrock RPM intake. I am gasket matching the intake ports to a Felpro 1205 which is a good fit to the Sportsman heads I have and I started wondering if milling this down would be a benefit.
Also how far down shoudl I mill it if I do it?
Old 02-22-2006, 08:35 PM
norvalwilhelm
norvalwilhelm's Avatar
I milled down a old high rise LS6 intake just like they did on the L88 intakes. The center divider was milled down about an inch. That was a great intake and when I upgraded to a single plane Victor Junior I lost performance.
I liked my milled down intake.
Old 02-22-2006, 09:31 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Take a look at the RPM Air Gap, there is 2 inch section milled down 1/2 in. It must work because the Air Gap only gives up about 5 HP @ 6500 HP to a Vic Jr on a 500 HP small block
Old 02-22-2006, 09:35 PM
MikeC
MikeC's Avatar
Yeah I was just looking at the Air gap in the Summit catalogue.
I'll put it on the mill at work on Friday.
Old 02-22-2006, 09:36 PM
GDaina
Support Corvetteforum!
GDaina's Avatar
Yes, you gain upper end performance at the expense of some mid and low range
Old 02-22-2006, 09:45 PM
yellow 72
yellow 72's Avatar
St. Jude Donor '09
I remember being told by a reputable engine builder, that with cam durations over 240* @.050 and if you spin it over 6000, removing the divider will help
Old 02-22-2006, 10:14 PM
big_G
big_G's Avatar
I had to modify the center divider on a Performer rpm this way to fix a tricky fuel mixture distribution problem between cylinders. This was a popular mod. in the late 60's and thru the 70's.
To Milling down plenum divider
Quick Reply: Milling down plenum divider
