Best way to remove carbon deposits?
The ORIGINAL and bestest
Toronto Events Coordinator
I currently have my engine apart, and before putting it back together, I would like to clean it up as best I can. What works best?
I would use fuel injection decorbonizer also know as throttle body cleaner. It works great. Read the label carefully. Its used normally in running engines...so I'm not sure if there are any negatives when used on a disassembled engine.
Jim
Jim
DON'T bead blast pistons ... never!
DON'T scratch pistons any deeper than thickness of a newspaper page.
DO soak pistons in gas ... use a plastic knife to scrape ... once you get comfortable w/plastic, switch to a small penknife ... take your time ... pistons takes awhile.
IRON heads can be cleaned with a wire brush in a drilll motor ... Aluminum heads treated like pistons.
I know you already have your engine apart, but when you finish it and have it back together you might want to use some preventative maintenance like SEA FOAM....Throw 1/3 of a can of this stuff down the throat of your carb while engine is running. It might bog down and shut off on its own (which is good). Wait 5 minutes, then start it again. You will then see blue to white smoke for a few moments and then it runs clear. You will soon notice a smoother, better idling engine. This needs to be done at least twice a year, before and after winter. Look at their website, seafoam.com, they have been around for over 50 years!!! It is also a better fuel stabilizer than stabil, in my opinion. Removes carbon from intake and carb.
Gonzo
Gonzo
GM makes a product called X66 that is made just to get rid of the carbon in the combustion chamber. Can buy at any GM dealership. Comes in a liquid or spray can I use the liquid version myself. You can pour it into the carb with the motor being moderately revved higher. When almost done you actually want to stall the car with the X66 and then you wait about 20 minutes to restart the motor. You will get the crop duster effect until the carbon is burnt off the pistons and rest of the combustion chamber. You can also use it to clean up the piston tops if you have them exposed allready. Put some on a rag and apply it to the surfaces you want cleaned. Just remember that you used the product when you first start the car again if you see a lot of white smoke. Most fuel injector cleaners also use X66 in them also, houstonvett
When I rebuilt the engine in my 74 I got some carb cleaner (the one used to soak a carb and its parts in) and poured it in a 3 lb. coffee can. I soaked the pistons in it one at a time and cleaned the ring lands with a toothbrush. After soaking and cleaning I sprayed them with brake cleaner. The pistons came out looking brand new and I've got 5 years on the engine with no problems.
as i understand it you are not taking the pistons out of the bores. I wonder if solvent will loosen the carbon and take it down into the rings?? Just a thought. It might be better to do nothing for now and just put some combustion chamber cleaner in it after its back together. I sometimes put a quart of transmission fluid in my tank. It seems like that prevents run on caused by carbon build up.
Friend Request Magnet
Originally Posted by windsoreight
I learned this from the diesel guys. Cascade dish washing detergent. In powder form mix with water and let soak overnight. Works great with no damage.
Thats the old trick to de-carbonizing Onan generators when apart.
If engine is together:
When running...add tranny oil...then high rev...squirt with water from an old dish soap bottle...then tranny oil again...the go run all the carbon out of the exhaust system...because the carbon WILL come off and out.
If you have a pesky neighbor; have him "watch the exhaust for balance, its a very important job"...then rev the motor...he will be coated from head to toe.
And you will smoke your house out like its on fire...but believe me; you will decarbonize what you are working on.
But if engine is apart...Casade and water...then hose off...rinse with regular alchol to displace water...then dip in tranny oil...let drip...use assembly lube when re-assembling.....done deal.
No scraping, scratching, marring or scaring...just clean.
Jim
