2004R vs 7004r transmission
Hey guys, i live in a small town with only one transmission shop. I stopped by and spoke with the mechanics earlier and they all recommended that i go with the 7004r because its a better fit for my 79 corvette. Well, i have read several posts here on the forum which most of the guys here went with the 2004r transmission vice the 7004r. I am not familiar with either one...can you guys give me some input...i sure would like to hear...as always thanks for you help..marty
The 200 is a bolt in box. The 700 needs the driveshaft shortened and the exhaust system re-routed. I'd go ahead and go with the 700 with the small block; it has a lower first gear for those out of the hole launches, if you're into that sort of thing. Do a search in the archives, many previous discussions on this very topic.
I put the Turbo 200-4r in my 79 because it was the same overall length as a turbo 350 so I didn't have to shorten the drive shaft. The trans mount is in the same location as a turbo 400 so you just have to remove the bolt-on bracket that your turbo 350 bolted to and bolt the th200-4r into place. A TH700 requires a shorter drive shaft and some work on the trans mount to bolt it down. None of this is rocket science. I would use what ever was easier and cheaper to come by in your area.
I met the engineer who designed the 200-4R when I worked at GM. He really didn't care for them. They were based on the chevette 200 metric trans. They had a limited run and in stock form were not know for their strength. However the 700-R4 had a longer run. It has gone throught vast improvments in the 4L60E. Since you can use the 4L60E internals in the 700 you can build a very strong trans at a reasonable price. The last 700-R4 I built is in a 69 Camaro with a 396 and runs in the 12's. I was a trans builder and am partial to the 700/4L60 platform. You will find many builders who never even opened a 200-4R up. Your money will go farther with the 700R4 than the 200-4R. If your engine is stock you could go with either. It would probably be less work to go with the 200-4R.
Do a search of the archives and you will find more opinions on this than you can count. Almost as divided as Ford vs: Chevy at a NASCAR race.
That being said, 700R4 is the way to go.
Actually, a good case can be made for either WITH a rebuild with good parts by somebody who has experience building them. If you do go with a 700, find an 88 up core to start with.
i'm running the 700r4 and i like it ....one of the biggest differences is that the 700r4 can be used straight from a junkyard where as the 2004r must be "built" since as a stock unit it is not strong enough
I'd go with a 2004R from Bowtie. Much better gear spacing: 1st=2.78, 2nd=1.57, 3rd=1.00, 4th=.67. Where the 700r4 has a lower 1st gear but a big jump to 2nd: 1st=3.06, 2nd=1.63, 3rd=1.00, 4th=.70
that gear spacing is only better dependent on the rear end ratio....with my 3.08s the 700r4 1st and 4th are better....if i had 3.73 the 2004r then the 1st and 4th would be better....but yes there is a difference in the spacing.
Well said! im not sure where the trans shop got the idea that the 200 is not a bolt in...
Originally Posted by PureSilver
may be OT, but how is the 4L60 different from the 4L80? I have a GMC van with the latter...seems to be pretty rugged.
St. Jude Donor '07
Originally Posted by Pete K
The 4l60 is a 4 speed version (with lock up converter) of a turbo 400. They are nearly bulletproof in stock form. They require an aftermarket computer to run it, due to the electronics.
I went with a 2004R and it's great. I think either will be fine, but the 200 bolted right in place for my TH400.
Originally Posted by 1972warship
I think he meant a 4l80E not the 4l60. The 4l80E is the overdrive designed after the th400...the 4l60 is the 700R4.
First time in months I post in c3 and I get it wrong
