Holly 830 cfm HP DP w/ annular boosters question
I purchased this carb but it is a marine carb. I believe the jets and PV along with the replacable air bleeds are close a "auto" spec. I went through the carb and set up the butterfly valves on both pri and secondary so only about .040 of transfer slot was exposed. Openned the four idle screws 1 turn. I turned the car over and it sputtered breifly and apparently flooded. No luck after that. Does anyone have the non-marine specs for this carb? Jets/air bleeds/powervalves/ pump squirter size?
Any help with set up would be great as well. I never have run a double pumper before with out a choke so I may be going about starting the thing all wtong as well.
Thanks!!
Thanks!!
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Thanks!!
Thanks!!
Clem ask you a great question. With the numbers you can find all the stock settings and parts.
.020 primary transfer ports. A good starting point is about 6.5 power Valve. A ball park primary jetting on an 830 cfm would be @77 and 84 rears. I wouldn't worry about the air bleeds because they are probably set up for sea level. One turn might be lean. go for 2 and then adjust it with a vacuum gauge while the motor is hot.
Non - choke carbs like my two vehicles. If the bowls are empty. Just hit the starter for 10-15 seconds and pump them full or turn on your electric fuel pump.
Then pump the gas about 4 times and leave your foot on the floor. Hit the starter. Boom - my 427 fires and rev up. I hold it about 2500 rpm while cold and you might even have to feather it to keep it going.
I know what the set up is for the marine carb, I just would like to compare the set-up with the 830 cfm annular discharge non-marine HP counterpart. Thanks for the help gkull, I will give that a try.
1 Post
Cruise-In I Veteran
Thanks!!
Thanks!!
I called Holley and yes at one time they did have a marine HP carb. Thanks for the Jet/PV info. I am not home right now and I am not 100% sure what my jet numbers are. Old age disease..... I have included my sig so yall can check out my specs.
