L-88 Fender Flares
Old 03-28-2006, 06:43 PM
pef427
pef427's Avatar
Default L-88 Fender Flares
I'm looking for pics and suggestions on what brand/why/ and where to get them. Should I get front flares as well or just the rear since I don't want wide anything wider up front?
-Patrick
Old 03-28-2006, 06:56 PM
StingrayDK
StingrayDK's Avatar
If you want the L88 flares these are the ones:
http://www.madvet.com/shop?frame=1.165.3484
If you dont want the wide look on the front i suggest you do something different like patsnitrovet who has a set of smaller flares at the rear and nothing on the front.
These flares will not make sense on the rear only.
Old 03-28-2006, 07:04 PM
comp
comp's Avatar
Old 03-28-2006, 07:16 PM
pef427
pef427's Avatar
Wow, those are a little pricey. Is that a true replica of an L-88 or just that company's style. I like the ones that taper back under the rear fender. If Patsnitro is around, please comment on your selction and why? Thanks.
Old 03-28-2006, 08:49 PM
enkeivette
enkeivette's Avatar
I plan to copy Pat when I'm ready for a new paint job.
Old 03-28-2006, 09:47 PM
PatsLs1vette
PatsLs1vette's Avatar
I dont know what brand i have but there smaller then the l-88 flares and i added alittle bit to them.I only did the rears because i wanted to keep the front looking the same and still run a 8 inch front rim.i guess i gained somewhere around 2 1/2 inchs or more i nthe back to fit the 17x9.5 with 4 1/8 bs,reason i didnt go bigger is cause i have a 3/4 sway bar still and it wouldve rubbed.But i might be removing that and going with a shorter rear spring and make my own offset trailing arms to fit 17x11's.
http://community.webshots.com/photo/...52841409qxvYZx
http://community.webshots.com/photo/...52841409wrZvSM
http://community.webshots.com/photo/...52841409ytBdJP
Old 03-28-2006, 10:38 PM
pef427
pef427's Avatar
Where did you get them? I like it!
Old 03-29-2006, 06:13 AM
PatsLs1vette
i had got them from a guy on ebay you couldnt remember where he bought them from,a couple guy on here thought they knew what they were,twinturbo has my front flares for his vette maybe hell know what they were.
Old 03-29-2006, 07:58 AM
Twin_Turbo
Twin_Turbo's Avatar
There are 2 common types of flares, the ones w/ the mudflaps like pat has and the non mudflap ACI L88 ones that are the same as the original GM ones back in the days.
The ZL1 flares are available in 2 different widths, I think Ecklers sells them but not sure. Showcars-bodyparts does have them but I heard some bad stuff about them, maybe it's true..maybe not. however, their (crappy) website does show what's out there.
http://www.showcars-bodyparts.com/corvette.html'
The ACI flares are just flare arches, the ZL1 flares are more of a quarter panel.
Here are the showcars ZL flares, 4"wide:
Old 03-29-2006, 08:02 AM
69Myway
69Myway's Avatar
Here is a tutorial for the do-it-yourselfer that wants to know what is involved in installing a set. We had to modify these to have "mud flaps" to fit the 81 body. These are ACI brand flares. They are said to be pulled off an actual L88 race car. I tend to believe it because they are not symetrical. These require a considerable amount of hand work to get them to lay in place and look right.
http://mcspeed.homestead.com/Flare_Install.html
You can see my flares at
www.mcspeed.homestead.com
You can see another set we installed and added the "mud flaps" at www.tropiczoneracing.com
Old 03-29-2006, 08:13 AM
Twin_Turbo
Twin_Turbo's Avatar
why not just cut off the mudflaps??? I'm grafting mine to an 82 body, just a little cutting and it fits like a champ. The yellow part on the bottom needs to come off
Old 03-29-2006, 08:26 AM
kursed56
kursed56's Avatar
Default Wow
Beautiful cars! The black Vette is outstanding.
patsnitrovette, I love the look you of your car, whats the story on the headlights? Is that a kit or a self "fabricated" piece? I love the round headlights. Im looking at a 74 with the square lights but cant stand them, the round just goes so much better with the car.
Old 03-29-2006, 09:08 AM
69Myway
69Myway's Avatar
Not a big deal either way. It is just a matter of preference and style. Some people like the mud flap bottom. In the case of TZracer and the black 81, they wanted to retain that part of the look to the car so we simply molded it in with the flare. I like the non-mud flap look as it really accentuates the tires.
Old 03-29-2006, 09:16 AM
Twin_Turbo
Twin_Turbo's Avatar
I don't like the mudflap either...I'm cutting it off.
Old 03-29-2006, 09:44 AM
69Myway
69Myway's Avatar
If you look close at the 81 Vette we went for a compromise look. We took a roll of tape and held it up against the roughed in flare. I then traced on the inside edge of the tape roll to get a symetrical curve to the lower flare area. We then trimmed off the flare and smoothed and hand workd that in place.
On the 71 Vette we built to the edge of the stock lower mud flap area.
It is interesting to note when I have traveled with the 71 Vette and ran through mud puddles, his mud flap area do a great job keeping the road grime off the body of the car. My car spins the wet mud and crud straight out and up splatting it all over the sides of the car.
Old 03-29-2006, 10:42 AM
PatsLs1vette
There L-88 headlights,i got the covers from guldstrand motorsports but there are other suppliers,i made the buckets from dimensions from an original set,but you can buy everything from themand other companys,but there not cheap.I still havent decied if im gone to paint them body color leave them black and black out the buckets too.
Old 03-29-2006, 03:40 PM
pef427
pef427's Avatar
Thanks Chris,
I like the non-mud flap look, so where can I purchase a set? Ecklers listed the whole panel ZL1. Not interested in that look. I think just the flares to mold into fender is what I would prefer.
To L-88 Fender Flares
Old 03-29-2006, 04:02 PM
69Myway
69Myway's Avatar
Originally Posted by pef427
Thanks Chris,
Contact these guys, or a vendor that sells their flares.
http://www.acivette.com/aci0004m.htm
Old 03-29-2006, 04:16 PM
Twin_Turbo
Twin_Turbo's Avatar
Mid America sells them for 100$ less than direct from ACI.
Old 03-29-2006, 04:28 PM
69autoXr
69autoXr's Avatar
ACI/factory L-88 style
Quick Reply: L-88 Fender Flares
