Ignition wiring with Accel DFI Gen 7
Hey guys,
I have the Accel DFI setup on my super-ram 502. Im trying to figure out the ignition wiring so I can install my dist.
I have the mallory hyfire box with their coil and the Accel DFI Dual Sync Distributor.
I have the coil wired to the box, now I need to wire the Dist to the box. The distributor harness has two wires that are supposed to be wired to the box, an unlabled pink wire and a purple wire labled EST POINTS (do not connect to - coil). Which wires do those go to?
Thanks for the help guys.
It's been a while since I wired and I can't seen to find the wiring diagram for my dual sync distributor, probably means it didn't come with one. . Have you bought the adapter harness for the distubutor? You need this to connect the distributor to the ECM. I am running a Accel ignition box. It has 8 wire but only uses 6of them.
power
ground
coil+
coil-
tach
and then 3 signal wires, only one is used.
The one signal wire that is used is connected to the white wire on the distributor adapter harness. My ECM schematics label this as "BYPASS" The tach wire is also connected to the adapter harness I think.
Also once you follow accels directions for phasing the distributor your advance will be set at something like 30 degrees. Make sure you get a timing light on it as soon as possible. Set the timing mode to fixed in the ECM and then match the distributor to that value using a timing light. When I read the instructions this wasn't clear to me.
power
ground
coil+
coil-
tach
power
ground
coil+
coil-
tach
power
ground
coil+
coil-
tach
Ok, cool thanks for the help - here is a paint schematic (lol) of my setup -
I just went out an looked at mine. My distributor harness has 2 leads one is a blue(could be purple, pin G, EST) that seems to go to the ignition box, the other is a black wire (pin H, Cable Shield) that gets grounded, although I for some reason mine isn't . I have all of my wiring taped into harnesses so it's hard to follow them the whole way. I can't find the white wire that the instructions my Accel ignition box's diagram refers to.
Going by your diagram, I would guess that the purple wire connects to the white or orange wire. I don't know which one though, but the install instructions for your box might say, I couldn't find them on cranes site.
I have found that Accel adapter harnesses vary sometimes. The adapter harness for my knock sensor had a different style connector that the one on the DFI harness. I contacted Accel and they had me chop the connector off and hardwire them. Also I found that the Accel EMIC near me is pretty knowlegable, there should be one near you that might be more helpful than Accel's support. I'm not bashing Accel's product, just their instructions/support.
