Attaching braided fuel line!
Does anyone know the correct procedure or fittings I have to order so I can attach my 6AN Braided Fuel Line to the connection on my fuel tank. I don't know if the new braided line slips over the feed coming from the tank or do I use a rubber fuel line on the tank feed and connect that to a barbed AN fitting. Just sorta lost about whats the right thing to do and I don't want fuel leaks!
I was originally planning on cutting the knuckle off of the large fuel senging line on the sending unit and installing the part linked below on the end.
http://store.summitracing.com/egnsea...t=RUS%2D639200
However, the piece of tubing on top of the sending unit just isn't long enough to accomodate this. You have the put the fitting on, then you need to slide it back far enough to fit your 37 degree flaring tool and there isn't that much tubing there.
I'm currently stumped on this and I'm looking for suggestions/alternatives.
I just did this job on my 76. I used braided line with AN fittings to run up the frame rails. I used the stock rubber fuel hose from the tank fittings to a barbed nipple with an AN fitting. These were joined with a male-male union. I did the same thing at the front to attach to the fuel pump and charcoal canister. The braided lines are pretty much the same length as the original steel lines.
I got mine from Pit Stop USA, but any of the usual catalogs should have what you need. This covered everything I needed to attach braided lines to my stock tank, except for the S-shaped hoses to the fuel pump and some regular rubber fuel to attach to the tank nipplies
1. Product ID: XRP230006
Product Name: XRP PERFORMANCE PUSH-ON STRAIGHT HOSE END -6 AN - #XRP230006
Quantity: 2
2. Product ID: XRP230004
Product Name: XRP PERFORMANCE PUSH-ON STRAIGHT HOSE END -4 AN - #XRP230004
Quantity: 4
3. Product ID: EAR981504
Product Name: EARLS ALUMINUM AN TO AN MALE UNION ADAPTER -4 - #EAR981504
Quantity: 4
4. Product ID: EAR981506
Product Name: EARLS ALUMINUM AN TO AN MALE UNION ADAPTER -6 - #EAR981506
Quantity: 2
5. Product ID: EAR300104
Product Name: EARLS STRAIGHT AUTO-FIT HOSE END -4 AN - #EAR300104
Quantity: 4
6. Product ID: EAR300106
Product Name: EARLS STRAIGHT AUTO-FIT HOSE END -6 AN - #EAR300106
Quantity: 2
Quantity: 2
Quantity: 4
Quantity: 4
Quantity: 2
Quantity: 4
Quantity: 2
Quantity: 2
Quantity: 4
Quantity: 4
Quantity: 2
Quantity: 4
Quantity: 2
Quantity: 2
Quantity: 4
Quantity: 4
Quantity: 2
Quantity: 4
Quantity: 2
Originally Posted by Victor
I just happened to have posted the same question yesterday on this forum. http://forums.corvetteforum.com/show....php?t=1385392
I don't understand. The russell fitting # 639200 does not require flaring. Looks to me that you could cut the knuckle off, slide the fitting on and tighten it down, it's a compression fitting.
Sort of like this:
Scooter, is that the top of your fuel tank or the bottom? Frig I'm all messed up here now. All my stuff is on the top of my tank, thats why I'm not sure what I'm looking at here! My order is in at Jegs so I hope I can my act in order while the parts are on the FedEx truck!
Indy
Indy
Indy
Indy
Originally Posted by Scooter70
It's been on there for a couple of years and doesn't leak a drop of fuel. I have the same type of fitting on the fuel rail at the engine.
That's good to hear! I have some of those fittings that I plan on using when I change over to an electric fuel pump.
