A Heads Up :Carbs with 'annular' boosters deliver super low end torque
Guest
Posts: n/a
Just wanted to share that , on my 1970 built BB motor, i switched from a 750 cfm SpeedDemon downleg booster double pumper Carb....to an 800 cfm Mighty Demon annular booster double pumper Carb ; the low end pull was incredibly stronger with the annulars. In fact, one magazine about a year ago, did a comparison and the annular boosters delivered about 90 ft.lbs greater torque than the downleg boosters (at 4400 rpms) , with both being the same CFM. Just thought id throw that out there for guys considering a Carb change who want max. low end grunt. Sure made the throttle far more responsive.
Dave
Dave
I want to do this so bad but I hate to throw away a perfectly good 650DP or even sell it used and shell out $650 for a new annular carb (what I would like to do is find a beat up 750DP, rebuild it, then have someone convert it to annular).
The CarCraft test was VERY compelling, here it is for people that want to read further:
http://www.carcraft.com/techarticles...st/index1.html
WOW interesting info I am in the market for a new carb for my (soon to be) +/-500hp stroker motor setup, sounds like annular is the way to go BG 850
I would like to hear any other thought on this subject too
Guest
Posts: n/a
If its off-the-line acceleration youre looking for, annulars are the way to go. On my setup, it was that 'pin you back' feeling after i made the swap in Carbs to annular boosters.
You would think there would only be annular booster carbs out there if you can get that kind of HP and Tq gain, why would anyone want one with downleg boosters, something fishy here
Guest
Posts: n/a
Originally Posted by SHAKERATTLEROLL
BLUE 2006 I have to ask why is everything about you blank? Or anyone else that might want to give some insight?
Originally Posted by Blue 2006
REPLY: Im not sure what you mean by this statement ; I hope it wasnt meant as an insult since your a fellow Corvette hobbiest .
I wish I had a annular carb to try. I went with the 750dp that BG recommended for me
Originally Posted by SmokedTires
If you look to peoples names to the left, you see when they joined the forum, colored stars, location, etc... yours just has you forum name
SmokedTires is correct I was not being mean just asking why there is nothing there as I have never seen this before.
Originally Posted by Bangkok Dean
I think he is on probation till he locates his flux capacitor. Now don’t anyone help him you know the rules he must find it by himself.
...and I was complaining a while back some forum members don't have enough info in their Public Profile, he dosen't even have a public profile
Maybe he is the trying to brainwash us into getting annular booster carbs over downleg booster carb, like Beta vs VHS wars a while back
I have a Race Demon carb that I am at the moment heavily modifying so I can get 550 - 600 HP out of my motor and still get over 20 mpg on the highway. I just might try these annular boosters in mine since they are replaceable and see if I notice any difference
East bound and down...
I went from an 850 Speed Demon to a 800 Mighty Demon with annular boosters on my 496 stroker. The difference was night and day. With the 800 I couldn't get rid of an off-idle bog. I tried changing pump cams, and even a 50cc pump, but I couldn't tune out the bog. The 800 is VERY responsive, it makes the car run out like a raped ape. To me, the power you give up on the top end is well worth what you gain down low.
