Pinion seal replacement???
Now that I get to actually drive my 81, looks like the pinion seal is leaking.
Is this something I can replace without taking the differential out or is it time to do a complete rebuild of the differential?
Thanks,
LannyL81
Thanks,
LannyL81
No, the alu diff has the pinion mount cast in and that prevents access to the seal & yoke, you have to take it out. Taking it out isn't that hard though and a good time to replace any worn bushings.
I thought you could - hmmmm....
Seriously ... you can't!
It's the one on the right. Now imagine the whole area surrounded by the frame and the driveshaft tunnel between the 2 storage boxes. I have tried it, there just is no way to work in that confined space to get to the yoke
you can on the 63-79 iron diff's just be careful not to overcrush the sleeve when you reinstall the yoke. Look over the procedures first.
Take it out!
Wow, you actually managed to get it done like that? That's increadible. Did you mark the pinion, nut and shaft to get it all lined up properly after torqueing it down? I had a hard enough time to get the driveshaft off...getting at those little bolts was a PITA and them being 12 points didn't help either.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by dwncchs
I have done it both ways on both diff. and you will be much happier taking it out.It is extremly hard getting the nut loose because of the lenght of extension needed.When you put it back you run the risk of crushing the sleeve too much like has been mentioned.Plus its a good time to clean and paint and inspect other things while their out.
Originally Posted by swensonm
So on a 74 you could correct?
Mike
Mike
Yes on a 74 with a homemade tool you can install pinion seals. Doug/carguy4sure borrowed it for his 78 and couldn't believe how easy it was.
Replaced the seals in both of my 79s. Didn't have any problem getting the old seals out or the new ones in. My handy dandy tool (below) and a 3' pipe on the breaker bar made breaking the nut loose and tweaking it back on to my scribe marks easy.
Used 1/8" X 1 1/4" X 36" angle iron($5). Space the holes so that it snugly cradles the flange and bolt it on.
https://www.corvetteforum.com/forums...tial-seal.html
Check out this link (it worked for me) definitely doable without a lift
Important to record torque prior to removal.
