Horn relay location '75
Old 07-05-2006, 10:49 AM
vwcorvette
vwcorvette's Avatar
Default Horn relay location '75
I checked with the search function--checked my chilton and other stuff. Can't find the horn relay. Upper horn works with power directly to it, lower in-op. Steering wheel has good ground. Bypassing horn switch does not solve problem. Wiring diagrams show relay, but its not part of the fuse panel. Appears as though the flasher relay is the only one on the fuse panel. Any help would be great. Even a diagram or photo.
Old 07-05-2006, 01:37 PM
GruntyPants
GruntyPants's Avatar
I might be hallucinating, but while looking through the AIM for my '69, seems like the horn relay was inside the console, to the left of the shifter...
There, someone will see this, tell me I'm wrong and you'll REALLY get the right answer!
Good luck!
Old 07-05-2006, 01:48 PM
steelblu75
steelblu75's Avatar
Default 75 Horn Relay
Hi! Just took a look at my 75 AIM. Page 397 shows horn relay to be in the main wiring harness, just above the fuse box. Went out into the garage and checked and it is there as indicated. Mine is a black , plastic enclosed relay, attached via a locking connector.Have to stick your head under the dash, looking up between clutch and brake pedals towards the fuse box. I actually took a picture, and will try to post as soon as I figure out how.
Bruce
Old 07-05-2006, 01:53 PM
vwcorvette
vwcorvette's Avatar
So far I've got under the dash, in the engine bay near the M/C, and on the forward driver's side inner fender!?!
Old 07-05-2006, 02:01 PM
norvalwilhelm
norvalwilhelm's Avatar
On a 75 it is directly above the clutch pedal under the dash. When you raise your foot to push in the clutch there is a good chance you brush the horn relay. It is just hanging down, dangling from the wiring harness.
I too have a 75 and changed mine about a month ago.
Look nowhere else but where I just discribed. It is black and seperates from the socket which has 3 heavy wires.
Old 07-05-2006, 03:27 PM
vwcorvette
vwcorvette's Avatar
No difference between auto or manual? Mines a slushbox.
Old 07-05-2006, 03:32 PM
sfallison
sfallison's Avatar
No diff. The relay's dangling under the dash!
Old 07-05-2006, 07:13 PM
steelblu75
steelblu75's Avatar
Think I figured out how to post my pictures
Or....maybe not....I'll work on it some more
Old 07-05-2006, 11:11 PM
vwcorvette
vwcorvette's Avatar
Found it afterwork this evening. Has power to it. Good continuity out to the horns. NO ground signal from switch. Column ground is good. Continutiy from relay connector to column(harmonica connector). But not from switch to harmonica connector.
Openned up relay--severly overheated! No good.
Horn contact below emblem broken.
Open somewhere in wiring in column. I'm thinking the spring loaded pin. Need to do further investigation.
Thanks for all the help!
To Horn relay location '75
Quick Reply: Horn relay location '75
