Need specs on 3 cams.. profiles por favor
oops... 3 plus 1....Would someone have quick access to these cam profiles... total
duration and lift please
1 LT-1 350/350hp....... the C3
2. Lt-1 350/370hp... ditto
3. Duntov 30-30
4. 1966 327/300
Thanks... if these and others are available in a single publication..
could you give me a heads up on what publication it is??
merci,
Kyle
3. Duntov 30-30
4. 1966 327/300
merci,
Kyle
You find them all on line at either Melling.com, Comp Cams muscle car series or FederalMogul.com under the Speed Pro line.
LT-1 GM 3972178, Speed Pro CS-1145R, Melling 22415
300 hp cam
GM 3896929 327/300
Valve Timing At 0.001 Intake Open 10.5 ATDC Closes 25.5 ABDC
Exhaust Open 37 BBDC close 15 BTDC
300 hp cam
GM 3896929 327/300
You aren't looking hard enough then.
Melling 22210 350/350 HP L-82 hydraulic cam
Melling 22200 is the 327/350 HP hydraulic cam
Melling 22410 is the 30-30 solid cam
Melling 22415 is the LT-1 solid cam
From the Federal Mogul site
CS1145R LT-1 350-370 hp cam
CS1179R 302 Off Road cam
CS113R is the Duntov
CS118R 327-365 HP cam
CS1095R is the l-82 cam
CS179R is the 327-350 HP cam
crane blueprint cams
Crane blueprinted
327/350 HP part no 967601
.050 dur. 222 int, ex, 222
LSA 114
lift int .447
lift ex.447
Crane blueprinted
30/30 cam part no. 967251
.050 dur. int. 254 dur. ex. 254
LSA. 114
lift int..485
lift ex. .485
crane bluprinted
140 off road cam part no.968821
.050 dur. int. 257 ex. 269
LSA 112
lift int..493
lift ex. .512
LSA 114
lift int .447
lift ex.447
Crane blueprinted
LSA. 114
lift int..485
lift ex. .485
crane bluprinted
LSA 112
lift int..493
lift ex. .512
