1977 horn relay location
1977 Horn relay
Thank you for he information. I found it hanging in front of the fuse box. I also was able to find the problem with my horn not working. There is a spring loaded plunger built into the turn signal switch which is supposed to touch the back of the cancelling cam. The spring was wasted and I replaced it. My horn works again.
Life is great.
Life is great.
