Dart small block 454/427
Originally Posted by Highhat
Anyone running one of those Dart raised cam, big cube, small blocks at 454 or 427?
My 427 small block Vette would just eat my friends 427 hot rodded big block 67 Camero. His Car and my lightened Vette might have simular weight. I had solid roller, 3500 stall with 4.11 and 4 speed OD. He has solid cam 3000 stall TH400 with 3.55 rear gears. Both cars are traction limited on street tires. any rolling start race or even side by side freeway from 60 - to off the end of my 140 speedo i just walked awy from him.
So IMO - CI is CI no matter if it's big block or small block
Originally Posted by Nemesis_152
as long as the heads breathe
Dart Iron Eagle has the raised cam, I will be going that route in my next build, you need special timing cover, timing set, oil pan etc. going to be expensive stuff
Is it a Dart block?
http://www.superchevy.com/technical/...g/0504sc_lite/
