MSD 6AL working, Tachometer is not....need the MSD Tach Adapter??
I just threw in the MSD 6AL, and everything is fine, however my tach no longer works. I have an Autometer "Shift-Lite Tach." I am using the output on the bottom of the distrubutor. Do i have to use the output on the MSD?? Or am i definitely going to have to use a MSD Tach adapter???
THanks in advance!
Chris
THanks in advance!
Chris
Re: MSD 6AL working, Tachometer is not....need the MSD Tach Adapter?? (pats406nitrovette)
I guess you can see my priorities here at stockton pat. Was here for a day and went home to get the vette. Im gonna try the MSD output and if not, ill go with the adapter.
I might take you up on that offer about your friend if i cant pass emissions next time i go through.
Chris
Anyone else know if ill definitely need the adapter???
Chris
