4 bolt L48??????
4 bolt L48??????
Is it possible to have a 4 bolt main L48? I thought only L82s had 4 bolt mains. A gentleman said he had his L48 rebuilt and they put a 4 bolt main in it. How?
There are a couple ways to convert 2 bolt to 4 bolt, rumor has it that coversion is stronger than original 4bolt. Someone will have an answer or a thread search will turn up some recent discussions
There are a variety of kits to convert a 2-bolt to a 4-bolt main.
The factory 4-bolt setup had the outer and inner bolts running parallel to each other, while many of the conversion kits actually splay the outer bolts, so they're angled away from the inner bolts. From what I understand, the added strength of this one operation is significant (but how much, I don't know).
Retrofitting a seasoned block for this, should make it a pretty stout basis for a high-performance application.
Location: San Diego - Deep Within The State of CONFUSION!
I think the question here is if you can have a base model vette (L48) and still have a 4 bolt main motor. The answer is yes, though it is rare. A small block is a small block (for the most part) and if you were building so many corvettes and needed a block, then you got whatever you had around (GM is renowned for this). Some L48 cars ended up with 010 blocks (according to the books I've read). When I rebuilt my 72 L48, it had an 014 block, and even some of those had 4 bolt mains in them (though mine did not).
Chances are the guy is not lying. Or he might have had the type of conversion that breathial suggested.
I have a 1980 L-48 matching numbers block with 4 bolt mains. It does happen. A forum member said he used to work on the line and if they ran out of 2 bolt blocks for the L-48 they would grab a 4 bolt to keep the line moving. Brent
Originally Posted by Trent Mayo
I just pulled the motor out of my 75 L-48 last weekend to start on my rebuild and was surprised to find that it was a 010 - 4-bolt main too.
Of course I could never be that lucky
So, the L-48 and L-82 were both 010 blocks but there was no external marking that designates 2 or 4 bolt main?
trw
Originally Posted by 72 stingray owner
...... Dropping the oil pan dispels all myths.
trw
trw
Yes, but that could trash all my hopes that I could have a 4 bolt!
Originally Posted by mvftw
I thought that the '010' block meant it had 10% nickel and the '020' blocks (rare) had 20% nickel...or something like that...
http://www.mortec.com/castnum.htm
