Vacuum line routing/connections?
Where can I locate a diagram off the various vacuum line connections? Specifically EGR and distributor lines. The assembly manual and service manual don't show these details.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Vacuum line routing/connections? (74-Roadster)
I hope this helps you somewhat, it might not be exactly like your car, but it should be close.
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
You can also give this a try:
http://members.home.net/awsvette/vacuum.htm
St. Jude Donor '12
I added another diagram to my site as well showing the same thing as what smokehouse posted. http://members.home.net/awsvette/images/eng_vac.jpg
The link is located in the carb project section.
