'80 brake fluid leak - master cylinder?
Old 10-24-2006, 10:35 PM
MN80Vette
MN80Vette's Avatar
Default '80 brake fluid leak - master cylinder?
As I was working on my new headers and clutch linkage (pics coming soon), I noticed that there is brake fluid dripping from the bottom of the p.b. booster.
I am assuming that the back of the master cylinder is leaking. What else could it be?
If that's the case, then I will probably replace the master cylinder and probably the booster too.
Where do you recommend I buy a new m.c. and booster? Any other recommendations?
Old 10-25-2006, 08:36 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Sounds like you need a master cylinder for sure. Booster should be okay unless you find brake fluid in the booster.
Old 10-25-2006, 08:43 AM
Jud Chapin
Jud Chapin's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Usually when there is brake fluid on the front of the booster behind the master cylinder, it's the mc that's leaking. If you have normal foot presure in applying the brakes, the booster should be okay. I'd replace the mc with a new one or a rebuilt one that is stainless steel sleeved.
Old 10-25-2006, 09:45 AM
genuine1980
genuine1980's Avatar
Booster should be fine if you press the pedal normally... you can get a master cyl at PepBoys, AutoZone, Etc... they are reletivly inexpensive. If you are going for Original from one of the corvette web sites, they can get expensive.
Old 10-25-2006, 11:07 AM
Ak. Mal
Ak. Mal's Avatar
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I bought a booster M/C already assembled as one piece from the local parts store. It was easy to install.
Old 10-25-2006, 11:21 AM
72LS1Vette
72LS1Vette's Avatar
I bought an assembled MC/Booster from Advance Auto for less than $100.00. Works great. The booster swap is a "challenging" job.
When you remove your MC, check the seal around the rod coming from the booster. My MC had leaked for years while the car sat and the seal just fell out, causing a big vacuum leak.
Rick B.
To '80 brake fluid leak - master cylinder?
Quick Reply: '80 brake fluid leak - master cylinder?
