High stall inaccurate dyno readings
Here is why I believe you cant completely rely on a dyno reading without a reference point. This is an 11 sec car, but the dyno only shows 337HP at RW, when it should be 450HP.
I think this low reading is attributable to high stall loose converter (3500). Any one else agree?
See this article: http://www.converter.com/whatsnew_dynamometer.htm
But in any event, it is useful as a comparison, as my head swap gained me 45hp and 50TQ over a greater range:
(388ci, 11cr)
(388ci, 11cr)
The absurd torque readings below the stall speed are obviously due to slippage, but the hp reading is reasonable. A well setup car will run 11's on that kind of rwhp.
Thanks.
The torque is that high due to the multiplication of the stall. The stall is definetly killing off some HP up top but. Lots of factors contribute to rwhp loss. Drive shaft/half shaft weight, gear ratio, tire type, type of oils used in the drive train, parasitic losses from the fan/fuel/water pumps etc.
The reason that car will run 11s is because its going to leave really good(assuming the car hooks). 500lbs tq at 2800, thats an instant hit, I bet that thing 60's in the 1.50s some where assuming the chasis is setup.
What all is in the motor?
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
This is also a Mustang dyno..they read a lot lower than a Dynojet does.
JIM
JIM
You think the stall is going bad?
Motor:
388ci, 11cr
Dart Pro 1 215, Super Mod Ported
CompCam XS-290S; 1.6 roller rockers
Victor Jr, 1inch tall, plus 1inch HVH Supersucker, & 1/2"phenolic
Holley 950HP
Turbo 400, 3.70 rear; 3500 stall
MSD ignition
Motor:
388ci, 11cr
Holley 950HP
MSD ignition
JIM
JIM
JIM
JIM
Damn I didn't even notice it was a Mustang dyno...LOL they definetly read lower
I don't think there is anything wrong with your car at all. On our LS1 cars, when we can "lock" a big stall converter, they will gain 20-30rwhp when using a 3600-4000 stall and locking the converter over letting the converter stall and flash. Not to mention a TH400 eats lots of HP also. If your car was a 4spd I bet it would make 375rwhp at least, and thats on the same Mustang dyno, on a DJ it would probably be 400rwhp which is 500 crank HP or so.
Either way that TH400 with that converter is what makes that car run 11s.
You have a copy of the time slip or remember the run? I am curious. How much does the car weigh? I want mine to run 11s also with a TH400.
Cruise-In VII Veteran
St. Jude Donor '07
What kind of 11 did you run. 11.98 or 11.3? Looks like your close to 400 at the crank, so that should be close to 11's, but your torque curve is strange for a 388. Should be a lot flatter.
Buddy: That torque curve is typical of a high-stall converter. They all do that.
EXACTLY. COMPLETELY different then a manual car powerband/torque curve
I am curious as to the details of the 1/4 runs and the raceweight. I have him around a theoretical 481hp at the crank. Thats probably a little low considering how loose his converter is. I bet he is really making around 500hp at the crank which is typical for a good 383.
Originally Posted by PNK
Have to agree with Motorhead here my engine was dynoed at 585HP and the chassidyno showed 449 RWHP
Thats about a 23% parasitic loss in the drive train/fan/pumps etc. Thats pretty damn good. I am assuming your car is a stick with an electric fan and fuel pump. I bet that sucker HAULS ***!
St. Jude Donor '07
Mine seemed to come out about the same 547 HP on the engine dyno
and 427 RWHP on a dynojet looks like 23 % loss too
Originally Posted by Budman78
Interesting, Why would you want an automatic behind a 383 then...??? Seems like you would want to build a bullet proof 8000 rpm 350, then waste money on a 383 torque monster with an auto. I've always been confused with this 383 thing. Help me out.
