Rear End Ratio??
Easiest way is to decode it from the stamping on the very bottom of the case. You'll have to put the car in the air to do this. Then post the code here and someone will tell you how it left the factory.
While the car is in the air, you can put a chalk mark on the driveshaft and one on a tire. Then have someone turn your driveshaft. You monitor the mark on the tire, they monitor the mark on the shaft. Once the tire makes one revolution, they tell you how many times the driveshaft turned. If they same almost a perfect three turns of the shaft, then it's likely a 3.08. Three and a third, a 3.36 and so on.
Here is a rule of thumb
Gear Ratio RPM@70 mph
411:1 3800 rpm
370:1 3200 rpm
355:1 3100 rpm
308:1 2500 rpm
You should check the numbers on your differential because no one knows if Bubba has been there.
411:1 3800 rpm
370:1 3200 rpm
355:1 3100 rpm
308:1 2500 rpm
obviously, the most accurate would be to pull rear cover. count teeth on ring gear, count teeth on pinion gear. rear ratio=ring gear/pinion gear. if bubba has been in there, rear codes may not do any good
Originally Posted by ginjam
How do I determine the gear ratio for the rear-end?
