Right Intake Gasket (size) for DART Iron Eagle 180cc Intake Runner Head?
I need to know if the standard size FelPro intake gasket for SBC is the correct gasket for use with my Dart 180cc heads.
Sorry for posting this same msg several times but haven't seen a response...
For example, the Trick Flow Aluminum heads have taller intake ports and therefore requrie Fel Pro PN 1206. Just need to know if the intake port size on the Dart heads matches standard or needs to be taller (and if so, what Fel Pro gasket would match).
Thanks to all! :seeya
Re: Right Intake Gasket (size) for DART Iron Eagle 180cc Intake Runner Head? (TedH)
What intake are you using? Does the intake and the heads have the same size port? Probably so..... If in doubt call DART, they will guve you the correct answer without all the guessing. In the Summit catalog is a page that lists all the FelPro gaskets and it states the port shape and size for each.
