Brakes Won't Lock Up-'76
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I just rebuilt the front calipers and master cylinder and installed new front rotors, hoses and pads. After bleeding the system, both by gravity and with a Mity-Vac pump, the pedal feels fine and the brakes operate normally except they will not lock up when trying a hard stop. Any ideas?
First try on smoother surfaces or loose surfaces. Maybe you have too good of traction and tire foot print.
If you have trouble even when it should be easy then I would think you still have air, maybe trapped in the master where the vac gun would be almost ineffective. Did you tap on the master with a dead blow rubber mallet when bleeding?
Were you bleeding with standard bleed screws or check valve bleeders?
I had the same problem almost when I was bleeding...I was getting TONS of air out. I came to find out the air was leaking past the threads of the bleeders, and then back out. I was not even really bleeding. I replaced them with check valve bleeders that had a much better thread seal, and it worked like a charm and I got all the air out.
I don't think the bleeders should be a factor when gravity bleeding, should they? Anyway, I posed this question above regarding bench bleeding the m/c. When doing the bench bleed, the tubing showed no bubbles after 15/20 pumps. However, there is a valve (or something) in the bottom of each section of the reservoir that I continued to get bubbles from, even after many, many pumping strokes. Should there be no bubbles coming from them for a proper bench bleed?
It is my understanding that ANY air bubbles visible in the fluid, even while bench bleeding, means air is being pulled in from outside either at the bleeders or past one of the piston seals.
ANY air visible in the fluid means air in the system.
Well, maybe that's my problem. Guess I'll pull the m/c off and try to get the bubbles out from the valves.
I think you can do it while it's in the car. The fluid won't drop down into the lines too far because all the bleeders are closed. Just be ready to install the nipples and tubes as you pull the brake lines. Then, making sure you have a good seal with the nipples, pump and pump, and tap on the master with a wooden handle or a rubber mallet and keep pumping.
Thanks for the tip. I went for a half hour drive or so and the brakes are now fine. I guess the bubbles coming from the bottom of the reservoir worked their way out by themselves. Thanks again...You da man!
Bubbles just below the master could work their way out as the pedal is pumped.
Remember air is lighter than brake fluid.
the bubble could slowly work its way up to the master. When you pump the brakes the master purges the air bubble.
I've run my master dry before and had the spongy brakes. If you let it sit a while and pump the brakes the air will work its way out.
I'm sorry but I have to disagree. Is there a source you have that tells you this?
If all you had to do was let the air rise, and pump the pedal then no one would have to bleed their brakes, and runout rotors wouldn't cause so many issues with spongy brakes.
Just tear it all out, and install BIMBO brakes. All the great cars of our time have them.
