QJet Hot Air Choke to Electric Conv.
When converting a hot air choke on a QJet to an electric choke, you need to block the vacuum port for the choke assy. What is the best way to accomplish this?
I would imagine JB Weld would do.
I just bought some vacuum ports caps. They come in a blister pack of different sizes and you should be able to get them at NAPA or any other parts store.
Also, do not forget to plug the passage between the choke housing and the carb body...should have a little white plastic tube in it at the mo, helps with the locating of the choke housing to the carb body. If you remove the choke housing, you will find it behind it.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,919 Likes
Be sure not to use the choke cover gasket when you install the electric choke, or it won't see ground to complete the circuit.
