Help with piston & rod ID.
I have what I thought was a 69 or 70 350 350HP motor disassembled in my garage and I noticed on the inside of the top of the piston there is the letters "TRW". There are a series of numbers on the top of the pistons as well. These are dome type pistons and I was looking for a part number or way to ID these rods & pistons. Did GM ever use TRW pistons in their engines? Anyone have some pictures of 69 to 70 350 350hp or LT1 pistons?
Rick: I found this info. on a camaro web page. It lists the pistons as part number 3988051. I know the numbers on top the piston started with 3 but Im at work now and cant check for sure until I get home. I got an email from a friend that said TRW sold GM the forged pistons for these motors nut I was looking for more info. This part number is goping to be the tell I guess. The rods do not have any pink paint on them but I wouldnt expect them to after all the miles this motor probably saw. I was hopeing there was another way to ID the rods?
http://www.nastyz28.com/sbcmenu.html#pistons
TRW Pistons
Back in the area of the 1960 and 1970 and even later, the LT-1 and the Z-28 and many of the big block engines all used pistons forged by TRW and made for General Motors.
The LT-1 had a 1/8" dome and centered wrist pin. The L-82 also used TRW forgings but were flat tops but centered pins as well. All the big blocks that came with forged were by TRW. They were all considered to be the top end of the hi-perfomance engines from Chevrolet. These had the centered pins as well.
Harry P. Hunter
Harry P. Hunter
I believe the number stamped on top is 3942545, which does not seem to be listed on the webpage you mentioned (however, that page only lists up to a '69 L46, then it goes to '70 LT1):
Here are all the pistons and rods before install. You can see some of the pink paint on the rods (I couldn't see it before they were cleaned up):
Do these look like yours? I thought my motor hadn't been touched before the machinist told me the pistons were replacements, but maybe he was mistaken and everything's all original. Now I'm curious.
Piston & Rod ID
Those 8 assemblies look like the LT-1 pistons and I'm pretty sure if you examine the rod caps you will see a letter O forged into the bottom.
If that letter is there those are the original pink rods without question and they have the right paint also
The forging numbers on the pistons may not be the part numbers that are used in Chevrolets catalogs. Often the casting or forging numbers are seperate but close.
Harry P. Hunter
Harry P. Hunter
Harry P. Hunter
Harry P. Hunter
Are these the "O" forgings you're talking about?
Those pistons are the same as the ones I have. Thanks for posting the pic. Mine have allot of black carbon on top but they are the same or very similar. Mine have the number 336744 on top of the piston. Does anyone have pics. of the early L82 pistons?
Maybe I have the original pistons afterall? Here are some pics:
I hope ya ain't puttin those rings in there though. Good luck!!!!
Harry P. Hunter
Thanks Harry. Are you referring to the Hastings iron rings? When I took my block to the engine builder, he said I could get away with lightly honing it and not boring it over, so I chose to do that. But, he said I'll need to use iron rings because the moly rings I was looking at wouldn't seat properly. I figured that since I wasn't planning on racing or even using it as a daily driver that it wouldn't be a problem. Do you think that's a bad idea?
Like I said good luck.
Harry P. Hunter
I suspect your engine is an L-46 as opposed to an L-82. L-46 was introduced in 1969 while the L-82 was introduced in 1973. Check the engine block to verify the date of origin.
I believe the post I've copied below is accurate:
Found a old set of TRW sbc pistons #3942545 on the dome and 202-99 on the inside of the dome. Anyone have any idea if its a cast or forged piston? New to the post, have a 73 Nova, and a 75 Camaro.
That is the 350" L46 engine piston, the 350/350 HP engine. It is a forged piston, basically identical to the TRW aftermarket #L2304 F forged piston. Listed as an 11-1 piston(at blueprinted engine spec), has a .100" tall flat topped dome on it. Dome is approximately 4cc
Regardless of the technicalities, you have a set of original forged GM/TRW pistons.
The GM one you have is also forged....made by TRW for GM.
Received 3,136 Likes
Good information and all but this is a 14 year old post...
M
M
