No juice to purple wire on starter.
Old 04-20-2007, 10:16 AM
jim2527
jim2527's Avatar
Originally Posted by sperkins
OK. I'm now trying to test continuity on the purple wire from the starter back into the block on the drivers side firewall t0 see if it's broken inside the harness. Does anyone have a diagram that will show me where that wire connects into that block?
Bottom right hand corner.
At least you have a purple wire. I have: Battery cable, red wire on battery stud, black wire on battery stud, red wire on "S" stud and no yellow wire.
edit for picture add....1970 harness
I'm gonna kick Bubba's azz.
Old 04-20-2007, 10:35 AM
MixxMaster
MixxMaster's Avatar
Hey, where'd you get that cool chart??? Looks like it would really help figuring out connections!
paulmarquart (05-03-2020)
Old 04-20-2007, 10:42 AM
jim2527
jim2527's Avatar
Doc Rebuild...I think it was $12 or so. That chart has the front harness, rear harness, engine(ignition), A/C, power window, TI ignition, alarm and every other diagram except the dash harness. The charts are good because they are printed in the order you make the connections if you were to start at the main connector. Just follow it counter clockwise!!
Its very helpful.
Jim
Old 04-20-2007, 10:46 AM
jim2527
jim2527's Avatar
On a second note, has anyone ever tried to install a new engine harness like this one?
Easy. I'm doing mine today. It'll be done in a few hours.
Jim
Old 04-20-2007, 11:05 AM
sperkins
sperkins's Avatar
Jim
What are the odds of that.
How are you getting to the block on the firewall? I've got side mount headers so maybe that's the problem. It would be great if you could post some before, during and after pics.
Old 04-20-2007, 11:21 AM
MixxMaster
MixxMaster's Avatar
Its very helpful.
Jim
AWESOME! Thanks!
Old 04-20-2007, 11:34 AM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
ok guys its my turn now......i have 69 with 79 vette engine and an HEI set up.....and it had no engine or drive train when i got it...
so the purple wire is the power source to engage the starter?
i looked at my harness on the fire wall and there is a female spade connector attached to a wire so i'm guessing this is bubbas HEI hook up...
i will have to look for the neutral safety switch (NSS) set up since currently the trans shifter is sitting on the floor and has the NSS wires snipped
have to love bubbas liberal use of electrical tape
[IMG][/IMG]
IMG][/IMG]
[IMG][/IMG]
Old 04-20-2007, 12:16 PM
jim2527
jim2527's Avatar
Actually I'm just about done. I only need to make a Home Depot run for a few misc. nuts to fix Bubbas home style electrical work. I'm also adding all the factory braces and shielding to the starter so that adds a little time because it was never there. I'll take some pics....mostly after pics. Seriously, this is so easy a cave....
The colored diagram I posted is very helpful. It shows me where all the wires Bubba cut go. In my case some of the new wires, TCS for example, I dont need to hook up. If you have the AIM diagrams it shows where to route it in the clips.
Old 04-20-2007, 12:53 PM
sperkins
sperkins's Avatar
The purple wire is for the "S" terminal (on the engine block side of the starter). It is only hot when the key is in "start" position.
Old 04-20-2007, 01:27 PM
jim2527
jim2527's Avatar
Descriptions precede the pics.....
Disconnect battery:
Place car on jackstands:
Beginning at starter disconnect harness:
Work your way across the firewall disconnecting harness and labeling as you go. Its very helpfull to disconnect vacuum lines as they are installed after and therefore on top of the harness....
Lastly disconnect harness from firewall connector with a 7/16"?? (I used an 11mm) socket and swivel. Those with sidemount headers may be F'd.
I removed mine by feeding it down and pulling it out from under the car.
Old 04-20-2007, 01:36 PM
jim2527
jim2527's Avatar
Installing is almost as easy as removing. I feed it across the firewall first then connected it to the firewall plug and the starter. Doing it this way you have both ends connected. Now its a matter of moving it left to right to achieve the position.
The wiper motor connection is key. Too far to the left or right and neither connector will reach:
There are a variety of clips to hold the harness. Slight shifting of the harness will provide optimal placement. For instance, moving the harness a small amount pulls it away from the exhaust manifold and tight up against the firewall.
Before adjusting:
After adjusting:
Pictures from the AIM (assembly instruction manual) show the exact clips and placement of the branches in relation to the clips...
Replacing the battery cables in many times more difficult than this. I started on the cables yesterday and I'm not dont yet.
good luck,
Jim
Old 04-20-2007, 01:41 PM
sperkins
sperkins's Avatar
Man thanks for posting the steps. That doesn't seem nearly as scary as I thought. Does the bulk connector just snap in? Was it hard to take out the original one?
Thanks!!!!!
Old 04-20-2007, 01:49 PM
  #33
jim2527
jim2527's Avatar
Thanks!!!!!
Removing the pld is easy. If you want to do it in 5 minutes just cut it out. Or, you can take 20 and actually label and disconnect everything.
The bulk connector has an integrated bolt. As you loosen the bolt the connector pulls away from the firewall. You may have to loosen the bolt a little then pull the harness away from the firewall then loosen the bolt a little more. The front harness slids off to the side.
The after carnage. Front and engine harness....
Old 04-20-2007, 04:28 PM
  #34
DJ Dep
DJ Dep's Avatar
St. Jude Donor '05-'07
Its very helpful.
Jim
Thanks for the heads up on that color wiring chart. I'm converting mine from auto w/AC to stick without AC and that color chart will be priceless!!!
Dep
Old 04-21-2007, 09:38 AM
  #35
shafrs3
shafrs3's Avatar
Yes that is correct, purple wire energizes solenoid. The HEI will need a switched 12v supply, I doubt any of those wires are for the HEI.
Wow, love that HP clutch cooler.
Old 04-21-2007, 11:34 PM
  #36
sperkins
sperkins's Avatar
That really is good news. Thanks again for the helpful hints. Where did you buy yours? I need to do both as well.
Old 04-22-2007, 11:08 AM
  #37
jim2527
jim2527's Avatar
I bought Lectric Limited harnesses through Paragon. If you place a $500 order with Paragon you qualify for some type of discount. Its actualy cheaper to buy them through Paragon versus direct from Lectric.
You should buy all of your harnesses from the same vendor to ensure compatibilty. There's something about mix-n-matchin' harnesses that doesnt go over to well with me.
Good luck,
Jim
Old 08-07-2011, 03:46 PM
  #38
xkeots
xkeots's Avatar
Default NSS on a 77
Where is the NSS on a 77 automatic? I seem to sometimes have no power when I turn the ignition switch. I replaced the starter 2 weeks ago and I put on a MR Gasket starter heat cover as my Y pipe heat was heating the starter. (it was) I want to make sure that I have total continuity there.
Jack
Old 08-07-2011, 04:55 PM
  #39
noonie
noonie's Avatar
Attached to the shifter under the interior console.
Quick Reply: No juice to purple wire on starter.
