How to adjust clutch pedal disengaging low?
I have a 71 with a new clutch. To get the clutch to disengage the pedal has to be mashed all the way to the floor. In fact the pedal has to be bottomed out on the floor. Is their a simple adjustment that will make the clutch disengage higher by about 1 or 2 inches? Thanks.
Do you have any adjustment left on your clutch rod going from the pedal to the cross shaft? If you do then you need to lengthen the adjustment by turning the adjusting nuts down the rod.
I don't know but will look. I'm guessing this is done by the cross shaft and not under the dash?
You will either need to replace the flywheel or shim the current flywheel. What has happened is that when you had the flywheel resurfaced you in effect moved it further away from the release bearing and pivot arm. You more than likey will not be able to change your release point with the linkage adjustment by itself. The standard pivot ball is not adjustable. You can purchase an adjustable pivot ball, but I do not think you will still like the release point even with this change. NAPA sells flywheel shims. The .025 shim is PT# BK6002744 and the .052 is BK6002745. I am going to install a new flywheel and be done with it. I have lived for several years with the same problem as you since my new clutch and pressure were installed by me, and the flywheel was resurfaced, and now that the Marcel on the clutch disc is shot I will take care of both problems at the same time. Good luck to you my friend. Vegas
I you're having trouble adjusting the stock linkage, I highly recommend the VBP Rod Links linkage. It gives you more adjustment and is much easier to adjust.
https://cmc.speeddirect.com/AMAZING/...atus=0&Tp=&Bc=
This pic shows the lower rod. The upper rod is adjustable too.
TIA
I meant SpeedDirect. The link I had in the previous post was correct. My typing wasn't. They are part #7500-125 for a stock clutch arm and 7500-1-125 for non-stock.
I don't suppose you have a part number for the longer stock pivot ball? I am just trying to save myself the disbelieving reply when I ask for it at the parts counter. Iam going to work from least expensive to most expensive on this. Thanks all.
At your local Chevy-GM dealer.
Well when I tried that method the longer pivot ball jammed the outer part of clutch fork against the openening of the bell housing, and also left zero gap between the throwout bearing and the pressure plate diaphragm springs. I ended up installing the adjustable pivot ball, but this still left me with a very poor dis-engagment point at the clutch pedal. You mess the clutch linkage geomerty up when you start trying to correct the problem by juggling the clutch linkage and pivot ball length. IMHO the correct way is to put the flywheel back to its original location. Vegas
No offense intended.
Now to fix the problem:
Take the clutch linkage loose from the pivot arm to the crossbar. Adjust the nuts of the linkage on the threaded rod coming out of the firewall so that with the pedal all the way up they are centered on the rod. Now get underneath and attach a short bungie cord to the crossbar and pivot arm to take up the slack.Measure the distance between the attachment points and buy one of these:
http://www.speedwaymotors.com/p/5891...t;-Thread.html
and two of thesehttp://www.speedwaymotors.com/p/62,1...quot;andB.html
along with a couple of jam nuts. Adjust as necessary.
I have a hard time believing that the loss of a few thousandths of an inch off the surface of a flywheel could cause the kind of geometry problems described here. Even with the use of a non-stock clutch there should be plenty of room for adjustment either at the pivot ball or the linkage itself. Replacing the flywheel is a ludicrous suggestion IMHO.
