C3 Ramps (pics & instructions) by popular demand
Not sure if this is the correct place to post this, but if not I am sure it will get moved.
I get lots of questions about these ramps so here are some pictures and the instructions are at the end of the post.
Instructions:
The ramps are indeed easy to build. Both sections are built identical. The ramps are 10'9" in length. You can construct them from 2"x10" or 2"x12". In this set I used 2"x10" and then nailed a couple of lengths of 1"x6" on each side on the bottom to give some extra lateral support. The top and bottom are 2"x10" with 2"X10" uprights on 16" centers. You will need 2 sheets of 1/2" plywood or wafer board for the sides. Cut each sheet of plywood into 3 strips 16" wide. It will take one sheet per ramp. Use 2 1/2" spiral nails or 2" drywall screws on the side pieces. Use 3 1/2" spiral on the framework. On the ends where the car comes up, spike another piece of 2" x 10" to support the planks for driving the car up on. These 2 planks only need to be about 7' long with a couple supports under them. With that short a length my side pipes still clear fine. I am going to mount a couple of permanent lights and a 110v receptacle on the inner sides of the supports. If you have a good level floor they will be very stable and will support a bulldozer. I can almost sit on the floor under the car but not quite. I mark the floor with a felt marker so that each year it only takes me about 5 minutes to place them and drive the car up on them.
Coming soon - The template for my bracket I fabricated to mount my GPS and cup holders. The bracket requires no modifications or extra holes to mount.
Instructions:
great ramps and very good pics of them.
would you mind if I pulled the pics and text off the thread and created a .PDF file of the info to post up on my website's tech articles page for others to benefit from? Your name would of course be listed as the author for proper credit
I don't know if I can drive a straight line good enough to drive up on that. It's not very wide and could do some serious damage if I slipped off one side. I think I'll stick with my jack stands for now.
Here are some others....Including my own.
http://forums.corvetteforum.com/show...ght=Johnny%27s
John
John
Wood Ramps
I've built a set and use them and like them a lot. It was kinda fun to see it come together strong where it needed to be. Had help from a forum member though. Compression loading.
Yup, my exact thoughts. Car is super clean Binnie, especially the underside, looks like you can eat on it.
