Anyone try the Holley Dominator 750cfm annular carb on a 383?
Veteran
I have the Mighty Demon 750 annular carb on my 383 just wondered if anyone tried this one yet?
http://store.summitracing.com/partde...5&autoview=sku
Veteran
Really I have no idea the advantage of the Dominator style over the standard other then your intake & air cleaner choices get a lot harder or you will have to put a bunch of adapters everywhere. I really doubt for street driving their would be much advantage that is why I asked the question if anyone has done it.
Veteran
I was debating between the Speed Demon 750 mech sec annular booster and the Mighty Demon 750 VC sec annular booster.
Without a doubt the Mighty Demon VC sec carb has run better on my car then any of the other Holley, Edelbrock, Quick Fuel(close second), and Speed Demon's and both vacuum and mech sec. Also once I re-gear to 3.90 or 4.10 in the next year or so I will probably bump the cam up as well and my carb will be still usable.
Veteran
I'm not looking to change carbs, I was just wondering if anyone was running the Holley 750 dominator on a 383. The only way I would switch from the Mighty Demon 750 annular is if Quick Fuel comes out with a 750 annular in the Q series. The machining and tunable options on the Quick Fuel metering blocks blow Demons quality away. All the emulsion & air fittings are screw in as opposed to drilling out the Demon metering block.
As for the Dominator 750, can't really see any reason to run it unless you want to fool someone and tell them it's a 1150cfm on your L48
Veteran
Yeah, but I was hesitant to go with as big as the 750 Mighty Demon, I think the Race Demon would have been a bit much for my HR 383 with 3.36 gears and a TH400, however if you can tune, any carb can be made to run good in my opinion on anything.
I just watched your video, that engine sounds nice, I plan on doing the Keisler 5sp conversion in about 2 years then I will bump up the cam some more to get the benefit from it.
As far as the dominator 750 I think it is a gimmick, I would bet it doesn't produce any bigger numbers then a 4150 carb.
Veteran
I have heard a lot of people complaining about the machining and the throttle linkage. I went to Jegs about 2 years ago when I had my original 350 and went through a couple of boxes of Speed Demon 650 that the throttle plates were bent. The transfer slot hole would be right at .020 on one primary slot and .030 on the other primary slot(example, dont remember exact numbers).
The Mighty Demon I just put on had bent likage on it preventing the primaries from closing after WOT, but I just massaged it with some needle nose pliers to free up its range of motion so it didn't get hung up.
I think a lot of people buy them and have no idea how to tune them so they think they are bad and send em back.
Although a lot of race shops here in Ohio have dropped BG Demon products altogether because of the amount of returns they had.
