what type ( bronze ? ) cam gear roller cam
Old 07-08-2007, 04:34 PM
StrayDog
Support Corvetteforum!
StrayDog's Avatar
Default what type ( bronze ? ) cam gear roller cam
Friend has 383 "stroker" has roller cam , the cam gear failed , bronze teeth gone...........he has owned corvette about two years engine was in his vette when purchased, engine is not a chevy crate engine but put together by bubba previous owner.................. the dist is an Accel w/pioints............ the cam is speed pro (fed mogul) roller retro fit..............my thoughts bronze gear as replacement he says steel i believe all roller cams have bronze gears am i correct............
Old 07-08-2007, 04:43 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Depends on cam material. Steel cores need a bronze or carbon/poly composite dist. gear.
Old 07-08-2007, 04:51 PM
SteveG75
SteveG75's Avatar
A lot of the newer retro-fit roller cams use an iron gear pressed onto the steel cam blank. This lets you use a normal distributor gear.
I don't know how many miles you frind has driven in two years but if he uses a bronze gear, they do wear very fast. Pretty much a replace every 2-3000 mile item. GM has a melonized gear that is also good insurance for roller cams. This is what I am using on my Crane retro-fit roller.
Good discussion of dist gears with pics here;
http://www.hotrodders.com/forum/comp...ion-96441.html
Old 07-08-2007, 05:04 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Got a Brand new MSD .500 ID Bronze gear I will sell for $30. If the cam is billet you need a bronze or composite gear. It is critical to set up the gear engagement correctly. If this is done the life of a bronze gear will be greatly extended.
Old 07-09-2007, 08:03 AM
StrayDog
StrayDog's Avatar
Amendum to my post >> To the best of my understanding the cam manufacturer will state what gear (dist ) is compatable with the material (metal ) the cam is made of >> the problem the cam in question is a "speed pro roller" , The company is now owend by federal mogal ........... need to see a copy of directions that came with the roller cam in question .if my neighber puts a steel gear in he may chew up the gear on the end of the cam >> however this may be a good thing as the cam he has runs in the 2200 / 6500 rpm range & he has a single plane intake ..he drives ( like grandma ) in the 1200 /3000 rpm range & also runs his 60 vette on regular gas ??? & this cam idles at 1000 rpm ..... a mild short duration cam & dual plane intake 180 would more so suit his driveing style..........the Dog
Old 07-09-2007, 08:42 AM
63mako
63mako's Avatar
Chewing up the gear on the cam is catatrophic. Then you have steel shavings throughout your engine, rebuild time. Find out the recommended gear from the manufacturer and set it up correctly. A properly setup bronze gear should easily run 25,000 miles in a babied street engine.
Old 07-09-2007, 09:05 AM
GDaina
GDaina's Avatar
Composite gear may be the safest route, but also the most expensive as the gear costs 110.00 plus
Old 07-09-2007, 05:21 PM
StrayDog
StrayDog's Avatar
however have been unable to do this , cannot (so far) get info from Speed pro cams ,company sold & sold again
my neighber is going to install a melonised cam gear.
Old 07-09-2007, 07:03 PM
TheSkunkWorks
Chewing up the gear on the cam is catatrophic. Then you have steel shavings throughout your engine, rebuild time...
...just ask redc3...
Old 07-09-2007, 07:06 PM
Scott Marzahl
Scott Marzahl's Avatar
http://21cgt.com/FMWebCatalog/default.htm
No mention of gear type required unless you pick a mechanical roller cam.
Old 07-09-2007, 08:57 PM
63mako
63mako's Avatar
It is his engine. I bet he has a Billet cam if he originally had a bronze gear. A billet cam requires a bronze or composite gear. Melonized is not on the list for billet cams from comp or crane. I wouldn't take the chance. Melonized gears are used on stock chevy roller cams but the metals are engineered to be compatable in that application. Different manufacturer, different metal. If it isn't compatable he will be building a new engine instead of replacing a gear. $110 is cheaper than a new motor.
Old 07-10-2007, 12:22 AM
Little Mouse
Little Mouse's Avatar
Crane cams .491 shaft #11951-1, .500 shaft 11950-1
Coated steel gear, replaces a bronze gear with
OEM life span. $61.95. inductioned hardoned steel billet,
or carburized steel roller cams.
Old 07-10-2007, 07:16 AM
bashcraft
bashcraft's Avatar
It's not on the list because they don't sell it. I've read of many people using this gear on billet cams with no problems. I'm running one on my Comp mechanical roller billet cam. I've pulled the distributor several times and so far everything looks perfect.
Old 07-10-2007, 08:53 AM
63mako
63mako's Avatar
I have heard the horror stories of running the wrong gear on a roller cam. Different manufacturers use different alloys to manufacture similar products. I would at least contact federal mogal and at least ask for recommendations. MSD uses a melonized gear. They don't live well with some roller cores.
To what type ( bronze ? ) cam gear roller cam
Quick Reply: what type ( bronze ? ) cam gear roller cam
