Teflon tape on brake bleeders.....
Old 07-11-2007, 10:30 AM
beto
beto's Avatar
Default Teflon tape on brake bleeders.....
Hi,
I know that there are Teflon coated brake bleeders out there but if I want to use my standard bleeders could I use Teflon tape on them to prevent leaks? Can I use it on brake lines as well????
Just curious.....
Old 07-11-2007, 10:44 AM
Jud Chapin
Support Corvetteforum!
Jud Chapin's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
You really shouldn't need teflon...if the bleeders are leaking, replace them with stainless ones.
Old 07-11-2007, 10:50 AM
bashcraft
bashcraft's Avatar
Originally Posted by beto
Hi,
Just curious.....
No, bleeders and flared fittings do not seal by the threads, they seal on the tapererd parts.
Old 07-11-2007, 10:55 AM
beto
beto's Avatar
Thanks, I believe that settles it.....
Old 07-11-2007, 12:42 PM
I'm Batman
I'm Batman's Avatar
St. Jude Donor '07
Especially on the lines, TFE tape can actually make the fittings seal worse, by keeping the fitting from applying proper pressure to the flared part of the line.
Old 07-11-2007, 03:20 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
use anti sieze on the threads it will stop them from rusting closed
Old 07-11-2007, 11:56 PM
tfi racing
tfi racing's Avatar
No.
Old 07-12-2007, 12:13 AM
...Roger...
...Roger...'s Avatar
But if your going to bleed your brakes with the hose in a bottle of fluid method then the teflon around the threads only will keep air from being sucked back in when you back off the pedal.
Old 07-12-2007, 12:16 AM
73, Dark Blue 454
73, Dark Blue 454's Avatar
Here's a trick for bleeding. If you suspect air is getting by the threads when you're bleedng, take the bleeders out and put grease around them.
Old 07-12-2007, 12:28 AM
sjmaster
sjmaster's Avatar
Excellent idea / advise !! I have two bleeders like that, so the vacuum won't work! I was actually expecting a caliper, stainless trailing arm lines and a set of bleeders from VanSteel today....but UPS has apparently screwed up.....but when I called to check, Dan told me the bleeders were not included.....Out of stock. So, what size do I ask for at Napa? I want to install my braided lines (already had those) and other goodies Friday night, and really don't want to hassle with the old ones.
Thanks!!
Old 07-12-2007, 01:22 AM
I'm Batman
I'm Batman's Avatar
St. Jude Donor '07
Thanks!!
5/16, IIRC. Go to the Help! aisle at your local parts store - you can get speedbleeders there. They're about $6 each.
Old 07-12-2007, 03:02 AM
sjmaster
sjmaster's Avatar
10-4 I will report to Pep Boys in the morning!!
Thanks!
Old 07-12-2007, 10:08 AM
strokervette
strokervette's Avatar
I'm also for the speedbleeders, they do a wonderful job in aiding the one-man brake bleed quest.
Old 07-12-2007, 12:33 PM
I'm Batman
I'm Batman's Avatar
St. Jude Donor '07
You need six bleeders, they come in packages of two. You might have to hit more than one store.
To Teflon tape on brake bleeders.....
Quick Reply: Teflon tape on brake bleeders.....
