Who out there has actually swapped an LS1/LS2/LS6 into their C3?
#2621
great info.... didnt even think about a catch can...
#2630
And what type of fittings are you using on the heater hoses?
Did you have to cut down the side of the water pump to make clearance for those fittings?
#2631
Received 1,116 Likes
Good thing aluminum is so easy to cut. Cut the side off the waterpump and the neck off the housing with my sawzall and tablesaw. Local guy welded the neck back on. The fittings are standard from Earl's or somebody like that. Note you need an a-arm solution that doesn't need shims for this to work.
#2632
#2634
what engine mounts did you use? I am doing a LS1/ T56 swap in my 64 that has steeriods also. I want the motor and trans as low as possible to minimize the mods I will have to do to the trans tunnel
#2635
Just added Steeriods to my LSX 418cid VETTE.
My 1st LS1 motor went in 2005..blew it up in 2008. My LS3 stroker has been in place since 2008... 08 LS3 block built by Texas Speed. I may have about 4000 miles on it. Oh Yeah I can run 10s and drive to the track...Drive anywhere really.
#2636
not a C3 but a LS1 T56 into my 64
not a whole lot of interest on the C2 forum but here is my LS1/ T56 swap into my 64
https://www.corvetteforum.com/forums...-upgrades.html
I have got some good info from this thread and if my 71 was not an original big block car it would have a LS3
#2637
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Because I have A/C mounted high on the pass. side, I put my Elite Engineering catch can on the radiator support. There is enough room next to the radiator to mount it, although unscrewing the can is a bit more effort.
#2638
Moderators, wasn't this one of those sticky threads at the top?
It sure warrants being one if not. what a WEALTH of information!
I see a book(s) that could be written JUST from the tech presented in this thread.
#2639
Moving this Thread here , basically killed the best Thread on here.
#2640
And don't forget the "LS directory" which can barely be found now....and would give ever LS related question asked in the past few years a person to direct it to.
https://www.corvetteforum.com/forums...directory.html
