Who out there has actually swapped an LS1/LS2/LS6 into their C3?
#2661
Donnie, there are quite a few examples over at LS1tech, go check over there.
I did read a few comments on making sure to ground them well.
You might even consider coil or engine covers. The C5 corvette ones look good. You could also check out the 2010+ Camaro cover that goes over the entire engine. I have one if you want to check it out.
Looking to clean up my engine bay this winter. I have LQ9 with truck coils and would like to relocated the coils and change out the valve covers. Maybe even paint the intake. Looks like I have about some room to mount coils on lower part of fire wall, same amount of area on driver and passenger side. Anything special besides extended wiring and longer spark plug wires? Do the coils need any protective shielding from weather?
#2663
Have any of you with aluminum block LS engines found the front end to be too light?
Was talking to respected shop about dropping an LSx into my car and he recommended a truck block to keep the front end from getting too light.
Thoughts? Comments?
Thoughts? Comments?
#2664
Ill take the 100lb weight savings (in just the block alone, no idea what the overall difference is with accessories, etc). Do you do a lot of racing at the track? The only place you are going to notice it is in the corners (over/under steer). If not, I would say do whatever suits you. Iron blocks are cheaper for sure. You may need to cut the springs in the front since you have less weight on the springs. Remove the spare tire from the back...now you are back at the same distribution
holley505 (02-07-2016)
#2666
Yeah... car sat up in the front... cut 1.5 Coils out.
