Clunking noise when shifting gears. Help?
Hi, My 71 small block, Muncie 4 speed goes clunk everytime I shift from 1st to 2nd and 2nd to 3rd unless I really slowly let the clutch out.
I changed the big rubber cushion mount on the differential and this took away the clunk from a standstill in first gear but it is still clunking in the other gears. I haven't checked the tranny mount yet but the motor mounts are in good shape.
What should I be looking for?
Clunk only happens when clutch is released into 2nd and runs quiet until shifted into 3rd. Shifts quietly into 4th.
Wouldn't u joints be a constant noise?
Also u joints were inspected and passed. Is there any other part that could be the culprit?
That I'm not sure of. I had mine replaced when I started hearing the noise. You might be able to move the shafts if they are really worn but I don't think they are that bad. Oh, and when I had mine replaced I also had the main and half shafts balanced. I figured while they were off it was worth the extra doe.
the rear diff if it has a lot of play in it will cause a clunk / even more so if your yokes going to your half shafts are worn out too this sound will be amplified by good but worn u joints
