81 strut rod bushing help
Rebuilding my 81 strut rods. Pressed out the outer rubber and internal metal sleeves. I have NOS replacement bushing which also have an external metal sleeve. Did the factory installed bushings have the external metal sleeve? Unless I am blind I cannot see the outer metal sleeve in the strut rod after the rubber and internal sleeves are removed. Anyone? Thanks, Joe
Thanks six Ft'r. Does this mean that after I sandblast the strut rod I just install the GM NOS bushings with the outer metal sleeve?
Thanks Again
Thanks Again
